F1 won't go into gear (430) | FerrariChat
Discussion in 'Technical Q&A' started by Daneuroman, Nov 4, 2013.
  1. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Western Massachusset
    Dan
    Hey guys my 430 wont go into gear. It is standing in my garage in neutral, and it wont shift into gear. When i hold the paddle for about ten seconds, i see the f1 transmission light (on the dashboard) for one second then it goes off. What could it be? I do hear the the f1 pump engage when i open the driver door and get into the car.
    Thanks in advance.
  2. tazandjan
    39,197
    Dan- You probably will not get this lucky, but check and make sure your brake switch is activating the brake lights and that all body panels are fully closed. Either can cause squirrels, with the former a large culprit.
  3. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    Lol I did check all those. I was reeeeeaaalllly hoping it was that. But still nothing. Thanks for the response.
  4. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    702
    Do you have a transmission light on or any other symptoms?
  5. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    No lights on. Fluid in the canister. No check engine nothing. It's driving me nuts
  6. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    Try the power reset. Might be a bad battery. switch off the power in the trunk for at least an hour and then revisit.
  7. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Make sure your rear hood is closed good
  8. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    Where is the switch? I cant find it. I officially bled the brakes and have full braking power and still the tranny wont go into gear.
  9. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    I believe others were referring to the brake switch located under the dash at the top of the brake pedal. when you look under the dash at the top of the brake pedal you will notice that if you push on the pedal with your hand a small pin is allowed to extend itself which closes the contacts in the body of the switch thus completing the brake lamp circuit. Turn the key to the on position (gauges and engine light will illuminate). Have someone in the rear watching for brake lamp illumination as you depress the brake pedal. If they see lights, the switch should be good.
  10. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    Brake switch is good. I'd like to do a power reset but can't figure out where the switch is.
  11. DanNE
    Jun 7, 2013
    702
    Disconnect the battery switch and go away for 1 hour (maybe even ~10 mins will do it but leave it longer).
  12. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    I have token out the battery completely for a whole day. Would that do that trick? Where is the battery switch? Thanks Dan
  13. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,674
    South East
    Jimmie
    RTFM section 5 p101 approx - luggage area
  14. DanNE
    Jun 7, 2013
    702
    Yes taking out the battery or killing the connection via the switch should be equivalent.
    Here's another test, when you press the paddles up-down do you hear anything whatsoever? When I had an F1 issue (different than yours most likely since I had a solid F1 fault light on) and I would press the paddles it would sometimes try to activate the gears and I could feel it in the seat (or behind the seat in the engine bay).
    Or is it completely dead when trying to pull any paddle combination? Try up, down, and both up/down -- assuming you are already in neutral.
    Also, does the 'R'-reverse switch do anything?
  15. gatorgreg
    gatorgreg Formula 3
    1,944
    NAPLES
    Greg Griffin
    On my 575 it would do the same thing. It was a relay switch for the F1 that would stick. Replace it or gently tap on it.
  16. DanNE
    Jun 7, 2013
    702
    If absolutely nothing happens when the paddles are used and yet there are no error lights, then I agree, probably an electrical connection so that the ECU does not even know you're trying to put it into gear...
    That's why maybe trying to use the 'Reverse' would work slightly different up to a point -- see what that does.
    If there are noises happening when pulling on the paddles but yet it does not go into gear then it's a different troubleshooting path we should look at.
  17. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    New development! We'll kind of, when I hold the shifter the engine revs go down as if it's about to go into gear. When I mean go down, like very slightly but enough to know there's a difference between holding the paddle shifter and not. Reverse doesn't work either. Is the f1 really behind the pass seat? Does anyone know if I can get that relAy at a generic parts store? Thanks for your help guys I'm hoping we can figure this out.
  18. DanNE
    Jun 7, 2013
    702
    This is probably not your pump relay (which is behind the seat) but another electronic connection. It almost sounds like you have a disconnected circuit somewhere in the paddle-ECU system. When the car tries to shift you hear a distinctive click from the transmission (behind you in the engine bay basically).
    If your pump was not running when you entered the car you could consider the issue of the F1 pump relay behind the passenger seat but I doubt that is the case.
    There's probably a way to activate the up-/down shifts at the ECU behind the passenger seat but you have to be very mechanically/electrically inclined.
    Also, do you have an OBD2 scanner? While not useful to troubleshoot transmission issues you could scan to see if there are any codes whatsoever and if they can provide any leads...
  19. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    I have run the scanner no codes whatsoever. I kinda wish there was.
  20. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    So still nothing. And I've run out of ideas all together.
  21. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    Can someone with an f430 hold down their shift paddle for like ten seconds without holding the brake and let me know what happens? I'm starting to think maybe it's my brake switch.
  22. CAracer
    CAracer Karting
    Oct 26, 2012
    228
    Pflugerville, Texas
    John Blanor
    My car acted similar to yours and it was the E differential solenoid. The dealer replaced it and the trans problem was solved. It cost about $1700 to replace with labor and parts.
    One last note, they had to put three of them in to get it right. I'm not sure if it was their install or defective part.
  23. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    That is never a good sign..especially for the DIY owner.
  24. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    PROBLEM SOLVED!!!!!!!!!!!!!!!!!!
    Some Idiot mechanic unplugged the hydraulic hose, but still left it somewhat connected. I had a friend come over figured a second pair of eyes might help. 30 mins later he found the issue. I was really starting to lose it.
    Btw, can anyone tell me what the proper oil level should be? After running the car for about 10 min I checked the dip stick and noticed it was somewhat higher than the second marking. Should I drain it, or keep it like that.
  25. up4speed
    up4speed F1 Rookie
    3,700
    Long Island, NY
    Chris
    That's great news!!
    I'm glad she's working well now.
