F1 won't shift with engine running | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Mel Spillman, Apr 2, 2016.
  1. Mel Spillman
    Mel Spillman Formula Junior
    731
    Sugar Land, Tx
    Eric: Clutch Pres. Plate travel is 17.357 with engine running. Any thoughts?? Mel
  2. tbakowsky
    Sep 18, 2002
    20,041
    The Cold North
    Tom
    Check the sensor side of the transmission input shaft speed sensor. Be sure the pins are all in place. I had one do the same thing. Turned out the center terminal of the connector pushed out some how, and resulted in a no shift. Or it could be the sensor itself gone bad.
    They won't throw a code somtimes.
  3. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    A quick check of the battery voltage value is a good way to know if the tool protocols are correct for the TCU - if the wrong software is being used you get something like 42v!
  4. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    Had the similar issue on my car after replacing the clutch. Everything was within parameters and car would go through the learning sequence without any problems but transmission would not engage when running (no gears showing on the dash). We replaced several sensors and the TCU without any success. Rifledriver finally sorted it out, the problem turned out to be two-fold; the replacement clutch was an aftermarket kevlar with different pressure plate so the bite point was outside of expected parameters and the TCU had an intermittent fault and was not the reading the input shaft speed (despite new sensor). Put OE clutch and new TCU and car has been running fine since.
  5. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    Any news???
    It would be interesting to know the root cause.
  6. Mel Spillman
    731
    Sugar Land, Tx
    Have not had a chance to do anything yet. Going to check the trans input shaft sensor first and I hope that is it. If not, going to look at the new kevlar clutch, but I really don't think that is the problem. I will post on the results. Thanks for checking.
  7. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Only NOW you decide to mention a Kevlar (non OE) clutch..................
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Ka Ching!!
  9. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    The most important detail curiously ommited...Perhaps this is a great case study in why most shops will only install and warranty OEM components.
  10. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    So, does that mean "most shops" won't install Hill Engineering bearings, Aftermarket exhaust components, non-Ferrari bought hardware (that still meets specification), intake / exhaust valves, valve guides ???
  11. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    #36 fastradio, May 12, 2016
    No, that means after you actually troubleshoot/repair an F1 car with aftermarket clutch issues, you'll understand why shops use OEM components. I thought the 30 odd posts made that pretty clear....
  12. fatbillybob
    Aug 10, 2002
    29,272
    socal
    LOL! So many tech help threads lack critical information. There will be a new one tomorrow.
  13. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Well there has been discussion re certain HE components within the pros here. Exhaust, only if legally compliant. Valve guides? You argued there is not an issue if I recall? Of course we, like most dealerships will use out sourced when equivalent to OE. With the huge parts price increase just from Ferrari, this may escalate too. eg Clutch position sensor just about doubled in price to over $900
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Nope, that was not my argument. And, it was no argument at all - I created this thread:
    http://www.ferrarichat.com/forum/348-355-sponsored-bradan/519350-poor-compression-high-leak-rate-%3D-bad-valve-guides.html
    And within it, I posted facts regarding my particular experience. No point posting the same again and it's all within the thread.
    I've had techs tell me personally and I've read it here that everything Ferrari makes is junk and then the same folks (nameless and not you Brian) post to only use Ferrari OEM. I find that a bit bizarre - don't you? :)
    For the record, I don't think Ferrari is perfect and nor do I think any manufacture is. I've seen some Ferrari parts that I feel are excellent quality and some I'm far from in love with.
    (and I'm a mechanical engineer and own a contract manufacturing company)
  15. Mel Spillman
    731
    Sugar Land, Tx
    The new Kevlar clutch is from GTE and is the exact same thickness as a OEM clutch. Had the OEM flywheel resurfaced .008 to flat, and used a new OEM pressure plate. All wires and connector on the trans speed sensor are OK. Next step is to switch out the TCU which worked perfectly prior to the clutch service. Again, many thanks for all your input and help.
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Mel are you aware of the break in required for the kevlar clutch. After talking to the guys at vivid racing i dcided against it because the break in they wanted would be more difficult in an f1 setup.
    Of course there will be many others i am sure that do not agree.
  17. Mel Spillman
    731
    Sugar Land, Tx
    Yes, I am aware of the break in, I just find it hard to believe that just changing the material of the clutch, with all the measurements being exactly like OEM, would cause the car to completely not shift when running. Thanks for your input, Mel
  18. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    #43 eric355, May 13, 2016
    Not very fair to tell now that the clutch is not OEM, but probably done on purpose to let us try to help you without focusing on this single point.
    That said, if I can understand that a non OEM clutch could cause strange things when trying to engage the clutch because of a very different "transmissible torque vs mechanism position" curve (and provided that ALL dimensions are like OEM), I fail to understand why it would prevent the TCU to select a gear with the engine running and with the clutch actually open (proved by throw out bearing position and by no speed on the input shaft).
  19. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Sometimes these things are a little sensitive to even the smallest change/error. Going through an issue with one now, changing back to all OE parts as well as changing more than I normally would on a clutch replacement.
    Right or wrong, the information about it being a non stock clutch material raises a red flag for me. I do not use these nor the rebuilt ones for a VERY good reason.
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Not sure if I missed something. Could you explain not shifting when engine
    Obviously it starts in neutral.
    Will it select first
    Will it select reverse
    Will it select second
    Have you tried low friction mode
    How about automatic mode
  21. Mel Spillman
    731
    Sugar Land, Tx
    Yes, it starts in neutral It will not select first or reverse or second. It will not select any gear in the low friction mode or auto mode. Thanks for your post and help. Mel
  22. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,467
    Dumpster Fire #31
    SMG
    Do you have a WSM? As much as most of the manuals can leave a lot to be desired the WSM on the F1 system is fairly comprehensive. I've only had 1 360 completely baffle me and pull my hair out, turned out to be inferior materials in the TO bearing seals that would swell after a short time and cause the clutch to stick, man that was a PITA to figure. But in one way I got a massive education in the F1 system. If you have a copy, I highly suggest sitting down and studying it, make notes. There is a lot of info in there, unfortunately it's not layed out in comprehensive manner like a text book but it's there.
    Oh and yeah for odd issues with the F1 system you have to use OEM factory parts to sort it out or you'll forever be chasing your tail. The TCU is programmed to work with the factory parts as designed and nothing else. Seriously.
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Mel as stated above that is what i reread before posting for you. If you read this section in the wsm you will understand how the system works. I believe some of the diagnosis you have allready gotten deals with the pis and as mel said if thats out of range it will not work.
    You might try letting the car warm up good and if might change the clutch temp enough that it will fall within specs.
    Good luck
  24. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Did you fnd a solution yet?
  25. Mel Spillman
    731
    Sugar Land, Tx
    Getting close. May be that the Leonardo needs to be re-calibrated. We have got it to shift and have driven it!!! Now trying to adjust the PIS so it won't creep. I will post the results, Thanks for checking in, Mel
