My friend have a 430 Scuderia and are having problem with the F1 shifting. The car wont start in 1:st but after some "thinking" it goes into 2:nd and drives fine. After starting in 2:nd he can go back to 1:st. Have anyone ever heard of similar problem?
By start, are we to assume you are referring to movement? Tell us more about the clutch engagement, or attempted engagement, when in 1st. Does it try to engage? Does the engine bog? Do the wheels slip/spin at all? What is the PIS? How did it start? If you want help you need to provide more specific and detailed information.
It is not my car just try to see if anyone has encountered similar problem before. The problem is described as: From cold starting the car and pulling the shifter to engage 1:st. The car does nothing and after "thinking" goes into 2:nd. Drives as normal no slippage or unusual behavior except wont start in first. After starting in 2:nd no problem going down to 1:st. No error codes from TCU. Hydraulic pressure OK, pump runs OK, relays changed. Currently looking into faults in actuator.
