News
348 F119 engine oil level.
Discussion in '348/355' started by JLF, Nov 1, 2019.
  1. JLF
    JLF Formula 3
    1,165
    I still am not super familiar with my Mondial T so I have a question.
    I checked oil level per the manual, when hot, right after shutdown and it registered just above half on the dipstick 400 miles ago.
    Then today I pulled the dipstick on a cold engine and there was no oil on it.
    Is it normal for there to be no oil on the dipstick when cold?
    Is it safe to start it up?
  3. MAD828
    MAD828 Formula 3
    1,859
    Elliott Caras
    It’s a dry sump engine so it will show no oil if the car is cold. You only test the level as per the manual when the car is at temperature.
    steved033 and JLF like this.
  4. JLF
    JLF Formula 3
    1,165
    Ok thank you.
  5. Ferrarium
    Ferrarium F1 Rookie
    2,924
    Central NJ
    Eric
    Yep first time I checked mine cold I had a heart attack. I check it when the water temps are normal operating temps with the car idling.
    Ga68_ likes this.
  6. JLF
    JLF Formula 3
    1,165
    Thank you. I figured it may be normal but was a little creeped out about it.
    Ga68_ likes this.
  8. steved033
    steved033 F1 Rookie
    Silver Subscribed Owner
    Apr 12, 2017
    3,266
    Atlanta, GA
    Steve D.
    I check my F119 when it's running.
    First time I checked mine hot (I also do it with the car on), i had a heart attack then put 4.5 quarts in. Fortunately I hadn't gone anywhere and it was day 1 pre-flight check. It didn't lose a drop up to my major, and hasn't lost a drop since. super weird.
    sjd
