F12 Brake Issues | FerrariChat
F12 Brake Issues
Discussion in 'F12/812' started by AaronW, May 8, 2017.
  1. AaronW
    AaronW Rookie
    Jun 14, 2016
    19
    NJ
    Aaron
    I just had a rock caught behind the rotor and heat shield on front wheel, caused a horrible grinding noise.
    Anyone have a similar issue
    Must say however Central New Jersey were great picked up the car like 6 pm Thursday and returned it Monday morning
  2. jbdmd
    jbdmd Formula 3
    Sep 30, 2007
    1,147
    Phoenix
    Doc Jay
    Yes. I had it in both my F12 and in my previous 991 TTS. In both cases the rock dislodged by going backwards.
  3. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    Nope but I did notice today driving from Geneva to Milano that I have to press on the brakes a helluva lot more than usual to slow down - was coming off from 2..kph when I first noticed and now every single time I brake I feel the "softness" in the early part of pressing on the brake pedal....
  4. AaronW
    AaronW Rookie
    Jun 14, 2016
    19
    NJ
    Aaron
    Thanks for the heads up regarding going in reverse, unfortunately the development I live in is still under construction so there are small rocks everywhere
    LOL maybe i should just reverse out to the main street
  5. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    Lol
    Sent from my BBA100-2 using Tapatalk
  6. tazandjan
    39,167
    Rocks trapped against the brake rotor are fairly common. Had one on a Jeep Grand Cherokee several years back. Drives you crazy until it is removed.
  7. Solid State
    Solid State F1 World Champ
    10,582
    Maximus Decimus Meridius
    I have my brake fluid flushed every two years minimum and it is hard to believe how much improvement you feel. Its the first thing you notice. If you are having trouble with pressure then just have it serviced.
  8. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    Brilliant advice, never thought about that. Approx how many miles/km do you do in that 2 year period ?
  9. Caeruleus11
    Caeruleus11 F1 World Champ
    11,618
    Yes, the rock against a rotor is a horrible sound. I'd be even more worried with carbon brakes- I would imagine this could chip or possibly crack the rotor? I had it happen last year on a BMW, fortunately metal rotors.
    I do break fluid change every year on my cars. I view it as cheap insurance. It not only gets me fresh fluid, but it also means my mechanic is taking a bit longer to look at the brakes. I'm not going to the track, but I can sometimes drive in a spirited manner, so its nice to have fresh fluid.
  10. tazandjan
    39,167
    Affirmative, me too, and I live in the desert. Important to bleed the master cylinder as well if you do it yourself. The factory tool can also bleed the ABS system.
  11. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    Brilliant! Thanks gents
    Cheers [emoji485]
  12. Solid State
    10,582
    First flush was about 1600 miles but not sure if they did a prior bleed so could have been a bit over 2K miles in three years. Second bleed was after only about 1000 miles and one year. I think time is also important so I believe every other annual is sufficient if not driven too hard; otherwise, I would suggest annually. I extended the full service on year three last year so it was free this time around along with the standard oil/filter plus air filters and secondary belt. Brakes are perfect and such a joy to use.
