F12 coilspring rates? | FerrariChat
Discussion in 'F12/812' started by Ozaki, Jan 28, 2016.
  1. Ozaki
    Ozaki Rookie
    Jan 28, 2016
    3
    Japan
    Rick Watanabe
    Hello everyone,
    I have a white F12 with the carbon option lights, and the SCM-E, but the car still rides a little high for my liking,
    Ive used the search button on the forum and internet and couldn't come up with much,
    Does anyone on here know the spring information, rate, etc ?
    I would like to get another set so the car can sit a bit lower on the front, as factory sits too high for me, anyone else thing it sits a little high?
    thanks
    Ozaki
  2. AutobahnAndTrack
    AutobahnAndTrack Formula Junior
    Dec 31, 2014
    307
    Frankfurt, Germany
    Stefan G
    Novitec sells lower springs.
    Anyone knows if they are also more firm than stock?
    Would like to have spring rate (+30%) and coil magnetho setup of TdF.
  3. Caeruleus11
    Caeruleus11 F1 World Champ Rossa Subscribed
    Jun 11, 2013
    11,612
    Novitec is probably the way to go. Their springs are typically 15% stiffer than stock. In speaking with their dealers they say this is safely within the tolerance of the standard suspension setup.
  4. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,166
    Ride height is adjustable on the F12 within a range of ~15-20 mm. Your dealer or suspension shop with Ferrari experience can do it for you. A full suspension alignment front and rear will be necessary after adjusting ride height, which will require a selection of shims for setting camber.
    First check your ride height to make sure it is set to the factory settings. Should be 134 mm + or - 5 mm front and 151.7 mm + or - 5 mm rear, measured from the pads on the bottom of the frame near the suspension.
    No spring rates in the F12 WSM.
