F12 exhaust valve control options | FerrariChat
Discussion in 'F12/812' started by hamptons79, Aug 10, 2015.
  1. hamptons79
    hamptons79 Rookie
    May 12, 2015
    9
    I was wondering if anyone knew what exhaust valve control options are available for the F12? I do not want to instal an aftermarket sports exhaust, but would like it to sound a bit louder below 2,500 rpm. I am either thinking a remote control valve control as seen on many 430s or just permanently wiring the valve open?
  2. Caeruleus11
    Caeruleus11 F1 World Champ
    11,469
    Im sure there are other options but check this out:
    Exhaust Bypass Valve Controller
    And you could just keep it open- it will sound great- but there might be times you'd prefer to have it a bit more quiet. I'd probably start off with just keeping the valves open. Your dealer can do that or any competent mechanic who knows Ferraris.
  3. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    The valve controllers work fine. I have a Capristo on my 458. My wife' F430 just runs valves open all the time. There is typically a slight low speed torque penalty due to the lessened back pressure but it is hardly noticeable if at all.
  4. Stradaleman
    Stradaleman Rookie
    Nov 3, 2003
    36
    Just added the Capristo switch on my F 12 it definitely enhances the sound at low rpm's even at idle. It is nice to have the option of switching it to quiet mode with the remote at certain times as opposed to having the valves open all the time
  5. Pesto
    Pesto Karting
    Sep 22, 2004
    76
    PalmBeachGardens,FL
    Douglas A. Benson
    Does installing one of these devices have any impact upon the factory wattanty?
  6. LARRYH
    LARRYH F1 Veteran
    9,568
    virginia usa
    I installed the capristo remote on my at the dealer prior to delivery on my f12 and was told it did not violate the warranty .. It may not hurt to have the dealer do it just to make sure ... makes a big difference..in sound at the flick of a button.
  7. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    my dealer installed capristo's prior to me taking delivery of the car, and i have since swapped the cats for NR sport cats and the NR ECU upgrade. Warranty in tact...so far
  8. GeeDubb
    GeeDubb Rookie
    Jan 25, 2019
    31
    Glen Williams
    Drop the panel down at the rear of the (just a few bolts and screws) unplug the vacume hose from exhaust valve, blank off the end of the hose and the valve outlet.
    Job done (takes about 30 minutes to do)
    This mod leaves valves open and gives a nice low down noise. No noticable drop in performance,
    Sent from my SM-G935F using FerrariChat.com mobile app
