F12 gas gauge accuracy? Need help | FerrariChat
Discussion in 'F12/812' started by DaveMc, Jun 21, 2018.
  1. DaveMc
    DaveMc Formula Junior
    Nov 29, 2012
    406
    Palm Coast, Florida
    Just bought a F12 and that 12 cyl. is thirsty!
    How accurate is the gas gauge? Has anyone run out of gas in theirs? I'm wondering when it says 25 miles left to go until empty, is that pretty close to being right?
    Thanks for any help
  2. MDEL
    MDEL F1 Rookie
    3,998
    Southern Europe
    Mario
    Never left the gauge on my F12 go to close to empty and I always fill the tank before that happens. The impression I have is that the miles left to go until empty indicated on the gauge might be more or less trustable at a moderate steady speed, for example on a motorway, but when you are accelerating it can change very quickly.
    Caeruleus11 likes this.
  3. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    Dave,
    One piece of advice, if I may: regardless of how accurate the instrument may be (and I would say it's fairly accurate in the case of my 458), never solely rely on it.
    I never left fuel in the tank reach below 1/4 and, if going at some pace, when the first bar on the fuel gauge drops below 1/2, I start actively searching for a convenient fuel station.
    Ferrari engines, being high performace oriented, use a lot of fuel when you're driving in a spirited fashion or when you're simply idling in a cold start. When on the road, unforeseen things can occur: a traffic jam, a detour, etc. Never run (that) low on fuel. Also, it can't be good for a Ferrari engine to have its fuel pump sucking on air.
    Kind regards,
    Nuno.
  4. GameMaker
    GameMaker Formula Junior
    Apr 17, 2014
    454
    WA State
    I've never run out but I've pushed it. It's fairly accurate. I still try to not get below 2 bars.
    Also this thing is THIRSTY.
  5. deltona
    deltona Formula 3
    Aug 7, 2009
    1,386
    Justin
    I assume when 3 bars left the car needs filling as the drop to 1bar can be very quick.
    Same in F12 and FF
    AlfistaPortoghese likes this.
  6. Red Sled
    Red Sled Formula Junior
    Last week I filled up just when the gauge dropped to last 1 bar out of 9. Took 80 litres to fill the tank which is approx 90 litres. So I would say the gauge is fairly accurate. However, the indicated range is highly variable based on driving style as other's have pointed out. While attacking some haripins on an Alpine pass, used up 1 bar within about 15 miles!
  7. Caeruleus11
    Caeruleus11 F1 World Champ
    11,470
    With the F12 when I see 3 bars left I start thinking about my driving style at the moment and fuel. If I am driving in sport and driving somewhat gently/ highway/ then I can rely on the miles to empty gauge- but 2 bars means fill up. If I am driving back roads and in Race then I look for the nearest gas station within 15 miles. Keep in mind in addition to other things, Sport and Race use different engine/ throttle maps. If you are running low on fuel I would go to the least aggressive mode and also select the highest possible gear. F12 is very thirsty.
  8. otakki
    otakki Formula 3
    1,634
    Another thing that makes it difficult is the lack of linear relationship between the amount of fuel in the gas tank and the number of bar, ie, highway cruising at around 80-85mph for around 100miles will take off only the 1st bar. For the next 100 miles, I cannot say for sure.
  9. PhantomCypher
    PhantomCypher Formula Junior
    May 25, 2014
    281
    The rule is on these V12 Ferrari’s is that one tick = 2 gallons. When you’re down to 2 ticks you’re basically at 4 gallons.
    Depending on how hard you’re driving at that moment that could mean you get 40 miles or 80 miles.
  10. Caeruleus11
    11,470
    I often do about 8MPG :)
  11. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,576
    Grant
    When you are getting low the car limits the power to help you save petrol, [ warning message says this] it works out this on your driving style so if you have been hammering it, it comes on early. This happened to me on my last lap at Silverstone, I had still had enough petrol to leave the circuit and drive 5 miles down the road to fill up [ at very low speed though as I was scared of running out]. 1 tank lasted 1hour 20 mins! Driving in France it lasted 4/5 hours in automatic on motorway at 75/ 80 mph with the cruise control on.
