F12 handling | Page 3 | FerrariChat
F12 handling
Discussion in 'F12/812' started by theV12Guy, Apr 4, 2020.
  1. Gh21631
    Gh21631 F1 Veteran
    9,301
    East
    We can get it done in one day and yes it should be aligned. We also added the valve controller which is a must. I figure I will try this before going to an exhaust.
    Pis7a2020 likes this.
  2. Gh21631
    Gh21631 F1 Veteran
    9,301
    East
    ilcapodizurigo, x z8 and Thecadster like this.
  3. Gh21631
    Gh21631 F1 Veteran
    9,301
    East
    Not too low, just right IMO.
  4. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,715
    I ve brand new Bridgestone S007; it s really the best tires i ve experimented on the F12, near of a half slick. It s like glue
    Look at the profile you ll understand why :
  5. Gh21631
    Gh21631 F1 Veteran
    9,301
    East
    Its like a different car, I highly recommend the Michelins. even with cold tires they grip very well. Also they seem to track better. The Pirellis would pull you in every direction if the road was imperfect.
  6. Eilig
    Eilig F1 Rookie
    4,229
    Tänzelndes Pferd
    Looks really good. How much lower than stock, about 3/4"?
  7. Gh21631
    Gh21631 F1 Veteran
    9,301
    East
    Cars with a lift are limited to ~ 1/2" in the front and rear was dropped enough to make it look level.
  8. Eilig
    Eilig F1 Rookie
    4,229
    Tänzelndes Pferd
    Less spring travel = slightly rougher ride? I did same w/Italia and its slightly rougher, but doesn't bother me at all on that car.
  9. Gh21631
    Gh21631 F1 Veteran
    9,301
    East
    Its hardly noticeable if at all to me.
    Eilig likes this.
  10. Ducati
    Ducati Formula Junior
    Jan 23, 2004
    364
    So. Cal
    Joe
    I have a 2017 F12 with the stock Pirelli tire. Recently on an on-ramp I jumped on the throttle and the right rear felt the tire was jumping off the ground
    as I accelerated hard. Some wheel spin I guess but a big boom, boom, boom from the right rear. The car did not move side to side at all but just stayed
    straight. The car was in Race mode. A suggestion was offered the try it in Sport mode. I tried that the next day and exactly the same thing happened.
    I backed off and tried it again same thing. Then shifted the 2nd and it did it again. These were relatively cold tires but....
    I tried the same thing again with a Scuderia the next day and nice smooth wheel spin. Does anyone else have experience with this problem. It is a Pirelli tire problem? Bad shock absorber. Any thoughts would be appreciated. I am thinking of switching to the Michelin 4S tire. PS. The roads in Southern California are wide open. One good thing out of this disaster.
    Shamsta likes this.
  11. Gh21631
    Gh21631 F1 Veteran
    9,301
    East
    I'll guess cold tires spinning and the traction control coming on. The Michelins made all of the difference on mine, it feels like a different car.
  12. Thecadster
    Thecadster F1 Veteran
    7,699
    What was the tire temp? My Performante is AWD and it hops up and down with “relatively cold tires”...
  13. Ducati
    Jan 23, 2004
    364
    So. Cal
    Joe
    Yes, relatively cold tires. It is about a mile to the on ramp But the same for the Scuderia. Also
    I had forgotten how hard the Scuderia shifts in Race mode. Almost. fees like a "power shift". Very fun!
    Nicky_Santoro likes this.
  14. Rosino81
    Rosino81 Rookie
    May 25, 2013
    40
    London, UK
    So is the consensus now that "compromising" on the K specification on the front tyres is preferred in order to get superior technology of the MPS4S overall ?
  15. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    There's no compromise. K spec does in no way define a quality or standard. Heck, if there was a 315 section for the rear, I'd say go with that to get a full neutral set. But seeing that the K spec 315 MPS4S is made specifically for the 812, I think it is safe to say that it will be a good match for the F12, despite not being the F12 tyre. If anything should be defined as compromised in this case, it would be the K spec and not the non model specific front.
    Looking at how narrow that 275 K spec tread is for the 812, I'd say one could also just run the complete 812 set. Many have tried the full TdF set on their F12, and it has shown to work really well, so I'd say it would also work with the 812 MPS4S set.
  16. ewright
    ewright Formula Junior
    Nov 17, 2003
    612
    Joe: it's wheel hop, or the tire alternatively gripping and breaking loose. I'm running Michelins on my F12 and it will occasionally do it when losing traction.
