F12 passenger display - trim removal | FerrariChat
Discussion in 'F12/812' started by profit1, Jul 24, 2022.
  1. profit1
    profit1 Karting
    108
    Hi, I’m trying to replace my passenger display on F12
    Anyone done this and can share any tips? Main question is which trim pieces need removal and how.
    Thanks!
  2. nguyennhatquang
    nguyennhatquang Karting
    Feb 13, 2016
    202
    Hanoi
    Remove your glove box..access it from there.. easy...
    why u need to replace it ?
  3. camshaft
    camshaft Karting
    142
    MA
    Austin
    Definitely do-able. With a mini ratchet set and some plastic trim pry tools much of the interior can be taken apart. Pretty much all the interior screws are T25 torx. It's just time consuming since the interior is almost like layers of an onion, having to remove surrounding sections before you can access the piece you want out. The workshop manual has step by step diagrams, which you can grab on ebay. You'll first open the passenger side door, and pop out the vent cover inside the door jam. It's held in by two snaps and the rubber weather strip. There is one mistake in the factory service manual though. The trim piece on the door side of the glove box is shown as being held in by only two screws. There are actually two more just behind it, so four total. The manual also says to pop the ball joint of the pneumatic piston for the glove box door off, but it's actually much easier just to unscrew the lower attachment for it since there's no risk to the plastic or piston trying to pry it off then. Also the glove box itself has about 11 screws, and many of them are different, so keep track of which ones went where. Once the screws for the glove box are out, it's wedged in by friction so you'll have to gently keep working it out until you can remove it. Be careful because it weighs about 11 pounds. That may be enough to have access to the display from underneath.
    This ratchet set was really helpful when I disassembled my interior:
    https://www.amazon.com/Sunex-9726-Mini-Ratchet-8-Inch/dp/B000XW4C8Q?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=ATVPDKIKX0DER&th=1
  4. camshaft
    camshaft Karting
    142
    MA
    Austin
    If the glove box isn’t enough to access it from underneath you may need to remove the main center dash which is more involved. I don’t have the display on mine so I can’t say for sure.
  5. profit1
    profit1 Karting
    108
    thank you all!
    helpful - i do now also see ferrari sells one-day access to the manuals for $275 - anyone ever purchase the one day option? assume the details are in there
    https://techinfo.ferrari.com/products/subscriptions
    yes - cover glass is broken (dont ask me how :mad:), good news is glass itself is sold separately for $70. based on above picture if i can access the front surface, looks glass is replaceable directly.
  6. camshaft
    camshaft Karting
    142
    MA
    Austin
  7. SeattleStew
    SeattleStew Formula 3
    1,017
    In the rain
    Stew
    I have a tech info account, and have used the 1 day option many times.
  8. nguyennhatquang
    Feb 13, 2016
    202
    Hanoi
    How u register for techinfo account.. I tried many time but they doesn't let me register.
    thank
  9. nguyennhatquang
    Feb 13, 2016
    202
    Hanoi
    thank
  10. SeattleStew
    1,017
    In the rain
    Stew
    I don’t know, I didn’t have any issues. I do know you need a business license, and I think it might be US only based
    nguyennhatquang likes this.
  11. nguyennhatquang
    Feb 13, 2016
    202
    Hanoi
    yeah that is the reason.. I don't have a bussiness license there..
  12. profit1
    profit1 Karting
    108
    Thank you everyone that replied, yes, is/was like like an onion... lots layers to open
    great advice camshaft!
