F12 pirelli vs michelin | FerrariChat
Discussion in 'F12/812' started by Pwillemse78, May 30, 2025.
  1. Pwillemse78
    Pwillemse78 Karting
    May 19, 2024
    153
    Valkenswaard
    Peter Willemse
    First of all, apologize for opening up a milked topic, but most threats were pretty dated so looking for newer input.
    3mm left on back pirellis 5mm on front. Switching to Michelin. Visited several shops, and was advised to go with k rating as they are Ferrari homologated. Seem to be few options:
    https://www.michelin.nl/auto/tyres/michelin-pilot-super-sport (k2)
    https://www.michelin.nl/auto/tyres/michelin-pilot-sport-4-s (K1) (only see back tires?)
    https://www.michelin.nl/auto/tyres/michelin-pilot-sport-cup-2 (k1)
    https://www.michelin.nl/auto/tyres/michelin-pilot-sport-cup-2-r (K1)
    the cup ones are too much as I drover during the winter too.
    Anyone any experience with the pss or ps4s? I always had the latter one on my Porsches…
    dealers only advice is to buy with k rating…
  2. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,256
    I've run them both. I believe pss was replaced with ps4s? I have whichever ones are current. tons of grip
    Senna1994 likes this.
  3. Pwillemse78
    Pwillemse78 Karting
    May 19, 2024
    153
    Valkenswaard
    Peter Willemse
    I am not sure. I only see that the 4sps only has the back tires with k coding not the front ones. So not sure there’s another option tbh ☺️
  4. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,354
    The Netherlands
    The K rating for the MPS4S does not relate to the F12 so it’s as good as pointless.
    The only K rated tyres for the F12 are P Zero or MPSS. The MPSS is impossible to get hold of and is old technology.
    Many owners have plenty of success with MPS4S (non K rated). We are running Conti SC7 but upsized and they work brilliantly.
    see here;
    https://www.ferrarichat.com/forum/threads/continental-sportcontact-7.693067/
    mdrums likes this.
  5. Pwillemse78
    Pwillemse78 Karting
    May 19, 2024
    153
    Valkenswaard
    Peter Willemse
    Right.
    I can get the mpss so might just try them for now… but indeed older. Maybe a non K s4s would actually do better… I’ll call the specialist here Monday am…
    ANOpax likes this.
  6. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,429
    Tampa FL
    P4S.... better tire than PSS. No need for K rating on the F12 as the P4S wasn't designed around it.
    x z8, Pwillemse78 and ANOpax like this.
  7. DZ-96
    DZ-96 Formula 3
    1,904
    South Germany
    Daniel
    Hi
    What about getting TDF rims and put TDF sizes on your F12.
    Perhaps with the TDF sizes you should get K sizes for front and rear.
    Daniel
    ANOpax likes this.
  8. Pwillemse78
    Pwillemse78 Karting
    May 19, 2024
    153
    Valkenswaard
    Peter Willemse
    That would be a lot of money, and I like the look of mine…
  9. Ngcanada
    Ngcanada Formula Junior
    May 16, 2016
    756
    Ottawa Canada
    For what it's worth, I finally switched my Pirelli's after a few years of replacing my rears with the Michelin PS4S and what a massive difference. I should have done this a long time ago. I find the power delivery is smoother and predictable than the PZeros. I have the K series for the Michelin, but I also have the 812SF
  10. Pwillemse78
    Pwillemse78 Karting
    May 19, 2024
    153
    Valkenswaard
    Peter Willemse
    can you send a link? I can only find the back tires k rated. Does the front tire look better aligned with the Michelin? Looks a bit too narrow with the pirellis, does not align perfectly with the rim.
  11. Ducati
    Ducati Formula Junior
    Jan 23, 2004
    364
    So. Cal
    Joe
    Maybe a little late for this one but I switched my F12 from the Pirelli P Zero to the Michelin MP4S and it was a major improvement. Much firmer sidewall and consistent control. But after a morning of hard cornering on Angeles Crest Highway the car pulled to the right. I went through several alignments and could not fix the problem. The dealer and I finally agreed to replace the tires and the problem was solved. At least one tire must have had tread delamination. I have decided to run a few pounds of extra tire pressure to hopefully keep that from happening again.
  12. Pwillemse78
    Pwillemse78 Karting
    May 19, 2024
    153
    Valkenswaard
    Peter Willemse
    thanks! I did switch to those Michelins too, and have the same experience. More grip and more stable. I can go full throttle now in first gear. Couldn’t with the pirellis. Glad I did!
    x z8 and Senna1994 like this.
