F12 tires | FerrariChat
F12 tires
Discussion in 'Technical Q&A' started by steve guess, Feb 18, 2019.
  1. steve guess
    steve guess Rookie
    Aug 21, 2018
    21
    Turks and Caicos/ Utah
    Steve guess
    Hi
    Two questions : what is the widest tire I can fit on an F12.
    Looking for recommendations on super softs for the same car.
  2. steve guess
    steve guess Rookie
    Aug 21, 2018
    21
    Steve guess
    I assume you will get more responses to questions if you create a cool fake name.
  3. tazandjan
    39,175
    Probably get more responses in the F12 forum. Look at the TDF wheels and tires for a clue. If you go to Tirerack's site and look in the specs for tires like the Michelin Sport Cup 2 and Pilot Sport 4S, you can check out the recommended wheel sizes for each size tire. You can put a pretty wide tire on the 11.5" rear wheels, but you need to make sure you do not deviate from front tire diameter to rear tire diameter differential by more than about 5% or you will have ABS issues.
    F12
    Five/Ten Spoke 20”, 5 X 114.3 mm
    Front 9.5J X 20 ET 48.4 mm, Rear 11.5J X 20 ET 71.6 mm
    F12 TDF
    Front 10J X 20 ET 48.4 mm, Rear 11.5J X 20 ET 57.3 mm
  4. steve guess
    steve guess Rookie
    Aug 21, 2018
    21
    Steve guess
    Thank you very much, this was very helpful.
  5. steve guess
    steve guess Rookie
    Aug 21, 2018
    21
    Steve guess
    Thank you very much this was very helpful.
    I did post the same question in the F12 forum and got nothing.
