F12 Upgrades and Dismal stereo Question | FerrariChat
Discussion in 'F12/812' started by Alexcle, Nov 8, 2019.
  1. Alexcle
    Alexcle Karting
    Jan 2, 2018
    188
    Alex D
    Hello All,
    i have found the F12 stereo underwhelming as per many comments on the forum. and dont know if there's a way to upgrade or just change the speaker or test see if its busted? The front plays faintly but seems like sound its mostly from the rear. Are most owners experiencing the same in the Ff, lusso etc? I checked the settings and it is balanced.
    In the meanwhile, I added the Max escort 360 ci radar , valve and,and a Fr & Rear dash cam. Some pics
  2. richard_wallace
    richard_wallace Formula 3
    Feb 6, 2004
    1,957
    Cincinnati, Ohio
    Richard Wallace
    There is really no stereo option for the F12 as it is integrated with the full right had control unit, nav, etc. etc. I had to replace mine just out of warranty ($10K), I searched everything and talked to a few high end aftermarket installers (as 10K would buy a heck of a aftermarket unit) - no go at all for any options as it is integrated. I do believe you can replace the sub, as it is behind the seat and should be plug and play to a degree. (PS OEM Sub replacement is 7-8K) - which the sub could actually be your problem.
    You likely can replace the speakers, however the size and shape, knowing ferrari - are such that you will not be able to find any that works without modifications. Not sure what they cost, but much more than you would expect/want to spend if you need to replace one or two that are bad.
    The sad thing is, as great as the F12 is (Though I had several electronic issues in my 1+ year of ownership = $30K worth on a virtually brand new car): The sub and radio unit are getting close to 10% of the current cost of an F12. The Turn Signal board (in steering wheel went out as well just after warranty, that was also several K) If Prices go much lower, the car will be worth more parting it out than to fix.
    First time I have said this, but with the F12, FF,GTC4, 812, etc. There is so much electronic wizardry and integration - I am not sure I would have another one without getting the extended warranty once normal warranty runs out. I was lucky and only about 1/2 the amount I had to fork out was out of warranty at the time, but I will say it does dampen the ownership experience - specifically when all the other Fcars I have owned have been a lot less expensive to own, and not as integrated components are part of that IMO.
    andyrichter likes this.
  3. Herane
    Herane Rookie
    Jun 16, 2019
    20
    Adam
    Hi, could you elaborate more on how you hardwired the dash cam in your F12? I really like the setup of your entire system (radar, dash cam and valves), very well done.
  4. Alexcle
    Alexcle Karting
    Jan 2, 2018
    188
    Alex D
    Got it. Thanks for the insight rick!
  5. Alexcle
    Alexcle Karting
    Jan 2, 2018
    188
    Alex D
    I had a shop do it and they originally quoted me 5-800 labor, for just radar install, once I added the rear radar and front and rear laser shifters, mounting the control in the console and front and rear dash cam with a battery backup, parts and everything came out significantly more.
    It took them 4 days to do whole install. Not something I could even contemplate. Took apart the center console rear trunk had to fish wire into the hatch etc.
    I used a power majic pro that came w the BlackVue 900k hooked it up to a battery backup so it doesn’t drain the battery and the battery charges when car Is running only. So it can record for like 15 hrs w car off which I can turn on and off w the majic pro’s on off switch
    They hid the hammers and everything very discreet, turned out well but expensive.
    Herane likes this.
  6. Caeruleus11
    Caeruleus11 F1 World Champ
    11,715
    I wonder if your issue is something simple like the fader? But assuming your settings are to your liking, then you could do an upgrade. A good shop should be able to do it for you. You can leave the stock head unit/ interface- there are adapters/ modules/ out there that will let you use this with an aftermarket amp and speakers. Just be prepared to spend some serious money ($6-12k is my guess depending on what you want to do).
  7. cwall
    cwall Karting
    Apr 10, 2011
    75
    I have been searching for tone controls and can't seem to find any way to adjust the sound, balance, fader, etc. that you would usually see on most car audio systems. Anyone have any idea if these adjustments exist? I have the JBL sound system if that changes things.
  8. blkfxstc
    blkfxstc Formula Junior
    881
    TX
    Eric
    They are in the right hand screen controls. You can get to them from the main screen or while listening to music. Fader, equalizer, and speed compensation volume.
    cwall likes this.
