F12 window switch blocker to prevent valet from pulling up on the switches | FerrariChat
Discussion in 'F12/812' started by colonels, May 5, 2024.
  1. colonels
    colonels Formula Junior
    Aug 5, 2011
    877
    i recently learned that you are supposed to only push down on the F12/Cali window switches so to lower is normal push down the front part but to raise the window you push down on the back part. what everyone else does including myself is you pull up on the front part of the switch to raise the window thus leading to breaking off the older clip on switches.
    usually it's valets who are in a hurry and apply way too much force upwards.
    can anyone 3d print a silver rounded block with adhesive that can be placed directly in front of the window switches that will prevent anyone's fingers from reaching under the switch and pulling upwards?
    attached is a crude illustration of what i mean. rounded edges would be better.
  2. Ngcanada
    Ngcanada Formula Junior
    May 16, 2016
    758
    Ottawa Canada
    Jesus, this is a first. I wonder if its the same of the Superfast. Going to have to check this out.
  3. colonels
    Aug 5, 2011
    877
    yes the 812 has the same center bridge with window switches in middle. however there was a redesign so the switch itself is now screwed on to the stalk whereas in the F12 it was simply clipped on with plastic clips. pulling up on the switch with too much force caused the plastic clips to break thus popping off the switch. however it was not intended to be pulled up on!
    if you look closely at the switches it shows you arrows on rolling down and up... the emphasis on UP being to PUSH DOWN on the back side of the button. but most people including myself always pulled up on the part where you normally push down to roll the window down. blocking finger access would prevent this and force people to do it the intended way.
  4. cryptyk
    cryptyk Rookie
    Dec 24, 2020
    44
    San Diego
    Ryan
    First I've ever heard of this. I've been pulling up on them (like any normal human being would) the whole time.
    I have a 3d printer - will take a shot at modeling something to solve it. In the case that you do block the front of the switches to stop valets from pulling on them, you'll need to make sure you roll the windows up before giving them the keys. No way anyone would think to push down on the back of the button.
    vraa, 350MH83 and colonels like this.
  5. colonels
    Aug 5, 2011
    877
    try pushing down on the back of the button it works just fine to roll up the windows
  6. Chewys5
    Chewys5 Formula 3
    Miami 2018 Owner
    May 17, 2010
    1,320
    Texas
    Shawn R
    We can definitely help you with this. We just need measurements or possibly a mold of some sort to make sure it is 100% correct.
    vraa likes this.
  7. Ngcanada
    May 16, 2016
    758
    Ottawa Canada
    Holy crap. I have had my 812SF for three years and with this discovery by the original poster, it actually does work. I had no idea!! Pretty neat little feature. Now I don’t have to succumb to the 12 Cilantro….Thanks!!!
  8. Solid State
    Solid State F1 World Champ
    10,591
    Maximus Decimus Meridius
    Never knew this! Been pulling up for 10 years. Maybe I'll get around to the radio settings or those overhead buttons some day. Thanks for the tip.
  9. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    Thanks for the heads up. I'll make sure to push the rear to close!
  10. colonels
    Aug 5, 2011
    877
    dimensions are 2 inches length by 0.5 inches height by 0.5 inches width
    preferably the same silver color as the bridge or close to it
    rounded edges and corners
  11. technom3
    technom3 F1 World Champ
    18,610
    Phoenix AZ
    Justin
    Thats just an excuse they made for a **** part.
    Every single button and switch is felt and held and fondled and caressed for sometime before making it into production.
    This is an excuse to say our parts don't suck. People do... If it was supposed to be a push here to open here to close it wouldn't have a giant lip to aide in lifting I. The front and there wouldn't be a giant recess at the leading edge to get your booger hooks under it to lift. It would be completely flat and horizontal with zero lips and recesses.
    But the problem still exists so... There is that.
    Chill47 likes this.
  12. Altoria F
    Altoria F Formula Junior
    Jan 24, 2020
    438
    France
    P
    Hmmm, I have no horse in any race but I have to say I highly doubt Ferrari designed thoses buttons more to be pushed down at the rear than being pulled up at the front.
    I ran my FF today: with it no doubt, it is not possible to push down on the rear of them, it made me thinking at this thread and I went to see the F12 when back home: in despite it is possible to push on the rear of the buttons it is also very uncomfortable.
    For my part I will for sure continue to pull up gently instead of pushing the rear of the buttons in the F12, and why would they have built 2 different principles for 2 so contemporary cars?
    Flea7 and vraa like this.
  13. JDT
    JDT Formula Junior
    324
    Denver, CO
    JT
    #13 JDT, Jun 1, 2024
    Agreed, mine don't push down in the rear very easily. In my opinion it feels pretty clear the buttons were designed to be pulled up and pushed down on the front lip but can be pushed down as well on the rear as the design allows it to function that way. Anything with to much pressure will fail eventually. I've yet to have any issues with mine. Maybe I'll try to get used to pushing down the rear of the button to see how that feels over time. Good info though for sure.
  14. Solid State
    10,591
    Drove the F12 today and tried pressing the rear of the switch and convinced it is not designed to do so.
    350MH83, camshaft and Altoria F like this.
  15. camshaft
    camshaft Karting
    142
    MA
    Austin
    Yeah I tried this also and I think this may be like one of those social media life hacks that isn't actually a life hack.
    DriIve and Altoria F like this.
