F12 with 275 width tires? TDF size? | FerrariChat
Discussion in 'F12/812' started by axis007, Jan 21, 2019.
  1. axis007
    axis007 Karting
    Jan 6, 2004
    83
    I currently have the 255/35-20 on the forged wheels on my F12, curious to see if anyone has ran 275/35-20 (TDF size) on their F12, and if so, any rubbing or other issues, it has 315 instead of the 305 in the rear and it seems fine....
  2. Exoticar Auto
    Exoticar Auto F1 Rookie
    2,990
    Tampa Bay FL.
    Exoticar Auto
    you don't want to do the 275 fronts on a non TDF F12.
    Caeruleus11 likes this.
  3. luigisayshello
    luigisayshello Karting
    Jul 9, 2014
    169
    If you are upgrading to michelins do it, in reality not that much difference on standard f12 chassis. The most you might ever need is a little less toe. I would prefer the 275 on a tdf wheel, as it is wider and will not influence ride height and by consequence, aerodynamics, but it's a matter of measuring the actual size differences of both tires on wheel.
  4. CrazyMD
    CrazyMD Formula Junior
    Mar 10, 2012
    404
    Southern California
    Why not. Do they not fit?
  5. F12_fanatic
    F12_fanatic Rookie
    Nov 10, 2018
    11
    Mano
    I had the same thing as you axis007 but since i race my F12 i didn't want to test that. if you still want to, try the 265 section other than 275s then see the results from there since its less risky to try 265 than 275 fronts
