F12tdf - Personalization Programme / Mesh & Water Issues? | FerrariChat
Discussion in 'FF/Lusso' started by sampelligrino, Aug 19, 2020.
  1. sampelligrino
    sampelligrino Formula 3
    Apr 16, 2017
    1,245
    If anyone has a copy of the F12tdf personalization programme, would love to have it and geek out over the available options and choices
    Separately, I bet the usage of the tdf is not on average the same as the F12, but does anyone know if the same issues that affect some of the F12s with the mesh/paint bubble/corrosion present themselves also on the tdf or if Maranello fixed this by then? Wondering about this and the rear brake light / hatch / water issues too.
    For that matter I'm even wondering about the mesh on my Speciale....seems like every modern Fcar has it somewhere on the exterior.. but only seems like the F12 has the corrosion from the mesh making contact with the body panels?
  2. Caeruleus11
    Caeruleus11 F1 World Champ
    11,631
    PM sent!
    I think most, if not all, of the metal mesh elements on the TDF connect to pieces made out of CF so I think this would not be an issue. Also I do not think the rear hatch suffers the water issues- it had to do with the break light, the rear hatch is different on the TDF.
    Bundy, uhn2000, junc and 2 others like this.
  3. sampelligrino
    Apr 16, 2017
    1,245
    As usual, thanks Jerry :D
    Caeruleus11 likes this.
  4. Andial
    Andial Formula Junior
    Jun 19, 2016
    395
    Please PM me too. Thanks.
  5. Solid State
    Solid State F1 World Champ
    10,598
    Maximus Decimus Meridius
    As far as I know, only the bumpers are CF on the F12TdF. The rest of the panels standard aluminum so the glorious triple vents on each rear quarter I would think have the same potential. Not sure about the 812sf as there are something like nine more grills and no CF body panels but I thought I saw that the grills were plastic - maybe someone else can confirm.
  6. Caeruleus11
    11,631
    You may be right - I think the rear haunches are also CF but maybe no? I bet its mentioned somewhere in the press materials.
  7. Solid State
    10,598
    I asked an owner before on this forum and did not get an answer. Knowing the body lines of the F12B and F12TdF you cannot have CF haunches without going up and over the roof and A-pillars so unless there is documentation to the contrary its just the bumpers and the aero-vents in the front. If you wanted to same more weight the hood and trunk lids are easy choices and then the doors which are more complicated. The roof and haunches would likely drive a full CF body deal like the Monza.
    Bundy and Caeruleus11 like this.
  8. Caeruleus11
    11,631
    That makes perfect sense. Thank you :)
    Solid State likes this.
  9. Andial
    Jun 19, 2016
    395
    I didn't get a PM yet. Still waiting.
  10. Caeruleus11
    11,631
    Sorry for the oversight! PM being initiated!
    Andial likes this.
  11. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,181
    Denmark
    Max
    Indeed. You can see Challenge64's unpainted TDF. All the body panels are brushed aluminum, but the bumpers which are painted to match the aluminum body.
    Solid State and Caeruleus11 like this.
  12. Jljr
    Jljr Rookie
    Feb 25, 2018
    49
    Miami Beach
    I checked all 812 mesh grills by using a magnet; all are metal, not aluminum or plastic.
  13. Solid State
    10,598
    Thanks. If the magnet test was positive for ferrous metal and the body is aluminum then its logical the potential exists assuming similar construction.
  14. BtvFerrari
    BtvFerrari Formula Junior
    Feb 12, 2020
    428
    The Netherlands
    A little bit late, but could you PM me too? Thanks!
