F149 engine oil pressure port | FerrariChat
Discussion in 'Technical Q&A' started by SupercarGTM, May 1, 2025.
  1. SupercarGTM
    SupercarGTM Rookie
    Nov 18, 2024
    34
    Dallas TX
    Is there another oil pressure port on this California engine other than the one under the intake for the oil pressure switch? There’s not a pressure gauge on this car and I’d like to at least occasionally be able to check oil pressure. If not I can use an T adapter but it would be great if there is an aux port.
  2. CCFT
    CCFT Rookie
    Jul 29, 2024
    4
    Southern California
    Might be worth looking into some of the aftermarket OBD gauges that might be able to read oil pressure from the ECU as well as other information
