F348 Brake Accumulator Pump Power Supply | FerrariChat
Discussion in 'Technical Q&A' started by 348noob, Jul 22, 2024.
  1. 348noob
    348noob Karting
    Feb 25, 2008
    94
    Singapore
    I’m getting inconsistent power supply to the brake accumulator pump at the fuse/relay.
    The wiring diagram shows that the fuse is Terminal 30 direct from battery, and indeed I do get battery voltage at the fuse when the ignition key is off. However, when I turn the key on, the voltage at the fuse drops to almost zero.
    This is very strange because Terminal 30 should be continuously on.
    I’m trying to locate the junctions/points physically in the car for the Terminal 30 line from battery positive post all the way to the brake pump fuse.
    I’m having a hard time finding these points. Where in the car is the first battery positive connector post/junction shown in the wiring diagram. Also, the diagram shows a “ABS connector” that splits the Terminal 30 to two different fuses for the ABS.
    These are the two main points I need to check, but can’t find them physically in the car.
    Hopefully someone here might know these locations so that I can test the points.
  2. 348noob
    348noob Karting
    Feb 25, 2008
    94
    Singapore
    I found the “ABS (power) connector”. It was in the bunch of wires below the row of ABS relays/fuses. A large red wire (Terminal 30) connected to and splitting into a smaller red and a smaller white wire supplying the relays. It had come loose. Problem solved.
    Qavion likes this.
  3. Qavion
    Qavion F1 World Champ
    14,281
    Ian Riddell
    #3 Qavion, Jul 23, 2024
    The battery bus bar is hidden behind the passenger footwell relay panel.
    It should have a plastic cover on it with a big, red "+"
