F355 2.7 engine/exhaust noise | FerrariChat
Discussion in '348/355' started by lanab, Dec 21, 2019.
  1. lanab
    lanab Formula Junior
    Feb 21, 2016
    516
    Stockholm, Sweden
    I am currently restoring a F355 2.7 which needs a major done where i will DIY most of the maintenance needed with time as this is one of several project cars i have.
    However i have a noise or rattle problem and I have tried to source where it comes from and would be glad if someone could give a guess from the video below.
    Early suggestion would be that the muffler is bad and probably the cats(already replaced by former owner, some cheap Ebay ones, EEC).
    I have no white smoke coming out from the pipes so i guess it can't be the exhaust valves, however i do get a solid slow-down 1-4 that comes and goes when the engine is idling and up to temp, however the RH cat doesn't seem overheat from the look at it so it can be a faulty temp ECU or probe, need to diagnos that more when i get time....
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,737
    When I lost the clutch/flywheel bearing in the pumpkin, it sounded remarkably like that.
    lanab likes this.
  3. lanab
    Feb 21, 2016
    516
    Stockholm, Sweden
    Thanks, i will remove the cats and inspect them and replace with test pipes first, i get a slow-down light from the RH cat so it could be a damaged clogged cat.
    I hate it when some owners gets cheap on these cars and buy the cheapest crap they can find just to buy time.....i found out the cats replaced by previous owner cost about $150/pair EEC FA6002T on Ebay.
  4. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    That may be coming from the clutch. Does it still make the noise when you clutch in and in gear and then almost moving the car?
  5. Qavion
    Qavion F1 World Champ
    14,420
    Ian Riddell
    If you have a piece of plastic tubing/garden hose held to your ear, it may help you locate the sound a little better.
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    You have to localize the noise first and then there will be better guesses.
  7. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    I tried this but the sound was the same on my Mac. LOL
  8. Ricambio
    Ricambio Karting
    Dec 30, 2016
    77
    Does it goes away if you give some gas (above dile ) ?
  9. lanab
    Feb 21, 2016
    516
    Stockholm, Sweden
    I have solved the problem now, i replaced the exhaust system from Nouvalari and replaced all hardware like donuts etc, however i kept the original headers as they are fine.
    The noise is totally gone now and it sounds as it should be.
    Qavion likes this.
