355 - F355 2.7 oil tank removal | FerrariChat
355 F355 2.7 oil tank removal
Discussion in '348/355' started by dvb247, Aug 1, 2020.
  1. dvb247
    dvb247 Karting
    Nov 4, 2012
    235
    Simple question I’m hoping, can the oil tank be removed without taking the engine out?
    The bottom bracket is broken and I have an oil leak from that area!
  2. fboutlaw
    fboutlaw Formula Junior
    Dec 3, 2014
    260
    Woodside, CA
    Looking at photos from my major. It looks like it should be removeable without the engine coming out.
    You'd have to
    1. Remove all the bolts and hoses to the oil tank
    2. Remove the fuel filter on the passenger side
    3. Likely need to remove the passenger side air plenum
    Then it looks like you'd be able to lean the top of the oil tank towards the center line of the car and pull it straight up and out.
  3. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    The side oil hose outlet on the tank stops you from removing it. The said outlet just wont get past the chassis diagonal tube.
  4. dvb247
    dvb247 Karting
    Nov 4, 2012
    235
    A Ferrari tech tells me it will come out no problem!!
  5. Mmckee
    Mmckee Formula 3
    BANNED Silver Subscribed
    Sep 30, 2016
    2,339
    Alta Loma, Ca
  6. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    No problem he says lol!! Ok
    I have been working on my 355 for 15 years, done everything to it from engine out to rebuilds.
    Will some one who has actually done the oil tank removal please sound of and tell us how to do it?
    The only thing that I have not tried was removing the RH plenum to try and get the room to get the tank out, but it's that oil take of against the tube that is the problem.
    Any one actually done this?
  7. dvb247
    dvb247 Karting
    Nov 4, 2012
    235
    Qavion likes this.
  8. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    Well done, so how did you get the oil take of past the tube?
    I guess not all 355s are the same. I cant do that with mine.
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,556
    San Carlos, CA
    Mitchell Le
    He's got an after market header which helps a lot. All he needed to do was disconnect remove the lid, removed the gas filter (if he had that in the way), removed all four oil hoses, removed the two mounting bolts, lever the tank toward the engine, and lift it out.
  10. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    Yea its weird mate, I cant do it on mine. Strange.
  11. dvb247
    dvb247 Karting
    Nov 4, 2012
    235
    It is strange, I followed the tube line when lifting it out and our cane out, I have a tubi manifold on, didn’t remove the engine lid or anything else, just undid all hoses and lifted out, my car is a 2.7 1995 rhd, as you’ve suggested there are differences with the 5.2’s.
  12. yelcab
    Nov 29, 2001
    13,556
    San Carlos, CA
    Mitchell Le
    Not very much difference in that area other than some 95 have a fuel filter there. Otherwise, it's even emptier in that space. 4 lines, 2 bolts, a wire or two at the bottom, and out it comes.
