355 - F355 / 355F1 Parts Thread | Page 10 | FerrariChat
355 F355 / 355F1 Parts Thread
Discussion in '348/355' started by CRAIGF355, Aug 7, 2011.
  1. EFerrari34
    EFerrari34 Formula Junior
    535
    Dallas, Tx
    Timothy
    Power Steering pump!
    FINALLY GOT IT!!!
    Spidan #53879
  2. MRF40@yahoo.com
    [email protected] Formula Junior
    Jan 1, 2006
    563
    Planet Urf.
    like whut? Ralph??
    Does anyone have a source for the side mirror servo motor? TIA!
  3. Qavion
    Qavion F1 World Champ
    14,635
    Ian Riddell
    The internals of the mirror motor assemblies seem to be universal on cars of this era. e.g. Jaguar. Someone was saying you can get identical motor assemblies for F360/550's from Chine very cheaply.
    https://www.ebay.com/itm/124763468494?epid=6041034771&hash=item1d0c7b72ce:g:9DwAAOSwTvhgv2Y9
    (I don't know if those side tabs on the case are used for mounting):
    Here's a picture of the 355's motor assembly:
    https://www.ferrarichat.com/forum/posts/144692800/
    Do you know if the motor/s are broken or the plastic levers?
    [email protected] likes this.
  4. Subarubrat
    Subarubrat Formula 3
    Apr 1, 2009
    2,072
    VA
    Scott
    Any chance the driver's side headlight motor is cross referenced to something available and common? The usual sources show it as out of stock, none coming up on ebay.
  5. m.stojanovic
    m.stojanovic F1 Rookie
    3,315
    Serbia - Niš
    Miroljub Stojanovic
    I presume that your "driver's side" means left side, p/n 172535. Did you try to google for "ferrari 172535"? I see a few, including on Ebay.
  6. EFerrari34
    535
    Dallas, Tx
    Timothy
    Fuel pump update.
    Bosch discontinued making the original part number for 355 5.2. I had it on order for 5 months with Summit & Vivid racing (both websites said they had it in stock & no one actually does). I finally talked to a Bosch rep who said the pump is D/C’d. So I bought the Ferrari Pump (Same Bosch part in a pretty box).
    You can still find the Ferrari Pump OEM.
    Outside of Bosch you can also use:
    Fispa 70997
    It’s listed around €132 on autofocus.co.uk
    That is the only direct replacement we’ve found so far.
    cavlino, Qavion and Carmellini like this.
  7. TipoF129
    TipoF129 Karting
    72
    Los Angeles
    ROBERT BROPHY
    Hi. Looking for euro turn signals for my 355. Any leads would be helpful! TIA!
  8. robcarter
    robcarter Rookie
    May 15, 2009
    6
    Worcs (GB)
    Robert Carter
    Hi Guys
    I had a broken flap actuator on my 355 5.2, found that the actuator fitted to a 2008 Fiat Multipla 1.9 diesel is the identical part, only difference is the fiat part has Valeo stamped on it rather than magnetti marelli. I bought mine from Ebay £20.00
    The Aircon distribution motor looks the same part as as fitted to an Alfa 155/156 - but the plug will need changing, saw a picture here
    https://alfa-restoration.co.uk/shop/product_info.php?products_id=2349
    Haven't verified as I repaired mine; I thought my motor had blown in the air dist actuator, turned out the commutator just needed the grooves cleaning out
    vincentf355, cavlino and Pepsi10 like this.
  9. Philipnz
    Philipnz Karting
    Apr 12, 2015
    227
    Whitianga New Zealand
    Philip Hart
    Just replaced my F1 Gear Display LED. A local electrics wizz swapped the failing one with this
    https://www.ebay.com/itm/153822386293
    I'm happy to report the new display works perfectly on all gears and is bright and clear
    There's a YouTube video that shows how to do it but the soldering is tricky and an expert is advisable.
    Carmellini likes this.
  10. phrogs
    phrogs F1 Veteran
    7,374
    Kzoo Michigan
    links die after so long, just for the part info here's a screen shot
    Philipnz and Qavion like this.
  11. NoMonkey
    NoMonkey Rookie
    15
    Texas
    I'm collecting parts for an F1 to Manual conversion. I recently picked up the shifter box from kennyd but am looking for any other parts. If you have anything for sale, please shoot me a pm.
    Thanks!
    Sent from my Pixel 5 using FerrariChat.com mobile app
  12. vjanos
    vjanos Rookie
    Nov 7, 2019
    5
    Vojtech Jánoš
    Hi, write to nick sevminasyan.
    I bought parts from him. Lives in Los Angeles
    NoMonkey likes this.
  13. CCWillF355
    CCWillF355 Karting
    Nov 14, 2019
    110
    London
    Chris Williams
    Wanted: engine deck lid. Don’t mind if it’s not the best condition as it will be repainted anyway.
    If anyone has one please me know?
  14. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,468
    Los Angeles
    Gang, this thread isn't the classifieds. It's for documenting vastly cheaper parts that are identical or nearly identical to Ferrari-branded parts.
    Teffers, taz355, Kokose7en and 2 others like this.
  15. Stryker1808
    Stryker1808 Rookie
    Jul 10, 2015
    40
    Hi all, does anyone know where I can find Parts 177790 and 177767 for my 355sp roof? These are the right/left main lift cylinder/hydraulic strut (photo attached).
    As background, I had converted the roof to manual operation as the electric roof was giving me lots of issues. Some of the youtube videos made it look quite easy but unfortunately, after a few months of trying it out, I think its too heavy for 1 person to bring it up/down. So I've decided to switch it back into electric (even though it has lots of issues, yes) but as luck would have it, I can't find where I placed these 2 parts now. Ferrari does not make them anymore and some shops like Top Hydraulics will only repair them if you ship in yours.
    My options are to (a) find these parts and perhaps have them upgraded at somewhere like Top Hydraulics or (b) somehow figure out to live with the manual roof. Overall it's been quite exasperating :(, so any help would be greatly appreciated. Thanks.
  16. Mike Morrissey
    Mike Morrissey Formula 3
    1,149
    Denver, Colorado
    Mike Morrissey
    I found today,
    64234500 Left Switches Mount
    15900270 screw for above are now available to order from the factory..
    64234500 - New - Genuine Ferrari Part)
    $8.00 each
    15900270 - New - Genuine Ferrari Part)
    $0.64 each
    Items 35 and 36. Eurospares
    ernie likes this.
  17. Minhwinn
    Minhwinn Rookie
    Apr 4, 2013
    5
    OC, California
    Yes, the one with red collar. Sorry I didn't notice the reply until now. Most of the suppliers are out.
    Qavion likes this.
  18. 355 P4
    355 P4 Karting
    Oct 13, 2020
    135
    So. California
    Bill Krueger
    Are you sure your 005 Throttle Position Sensor only has to 2 contacts. Mine has 3.
  19. Qavion
    14,635
    Ian Riddell
    All TPS's are 3 pin/3 wire
    ...unless you have an F1 with a two plug TPS
  20. Paulus 348
    Paulus 348 Formula Junior
    Dec 29, 2020
    353
    Holland
    Paulus Hollander
  21. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
  22. Paulus 348
    Dec 29, 2020
    353
    Holland
    Paulus Hollander
  23. FCOnyx
    FCOnyx Formula Junior
    May 28, 2012
    413
    Round Rock, TX
    Jeff
    Hmmm. I had to replace mine about 6 years ago as it went bad (starting having a "dead spot" in the middle of the range where power would completely drop out as if I had lifted the throttle completely). My tech put it on the SD to verify the original TPS was failing and dropping out. We replaced it (I bought the part myself and we swapped it together) with the part # I included above and it has worked fine ever since. Your 355 is a 5.2 F1?
