355 - F355 / 355F1 Parts Thread | Page 13 | FerrariChat
355 F355 / 355F1 Parts Thread
Discussion in '348/355' started by CRAIGF355, Aug 7, 2011.
  1. Cole_ve
    Cole_ve Rookie
    May 29, 2018
    15
    Cole B
    First post on this thread and hope it helps, closest thing I’ve found to the, maybe not important but, brake line holders that go all over the car, meaning plastic clips picture to follow… is:
    Ferrari part NLA: 141505
    GM part number: 94530240
    If you know of a more similar part…I’m all ears
    Also hunting for the same clip but for dual lines
    original^^^
    GM^^^
    05elise likes this.
  2. Cole_ve
    Cole_ve Rookie
    May 29, 2018
    15
    Cole B
  3. Johnturbo
    Johnturbo Rookie
    Feb 10, 2023
    32
    John Robinson
    Just to update this; I've found the Solenoid valve used for the exhaust valve to be a:
    PIERBURG ® 7.02256.29.0 also Ford Part Numbers 6580879 6580881
    Targatime likes this.
  4. Johnturbo
    Johnturbo Rookie
    Feb 10, 2023
    32
    John Robinson
    Interesting one here;
    The Ferrari 360 (and likely F430) front/rear wheel bearing is the same as (read: identical to) the F355 FRONT except in 2 regards:-
    * The 360 part has a different ABS sensor, and thus rubberlike core/inductor is bonded to the back of the bearing seals
    * The 360 part has a lesser dish where the hub-nut is fitted to the stub shaft; such that the thread engagement is at best borderline for 275 nm(?)
    So:
    After tapping the 360 sensor off the back of the hub; the ABS sensor core ring can be cut off the bearing rear shielding with a craft knife sufficient to clear the F355 stub shaft in 60 seconds. Easy.
    More difficult, but certainly doable is to have a machine shop bore out the hub-nut recess 5-10mm.
    Should be an easy job; I might have a go next week when my machinst is back off holiday.
    brogenville and Cole_ve like this.
  5. Johnturbo
    Johnturbo Rookie
    Feb 10, 2023
    32
    John Robinson
    (360 bearings are circa £600 and available. F355 circa 1400 and not available at the moment.)
  6. Johnturbo
    Johnturbo Rookie
    Feb 10, 2023
    32
    John Robinson
    Corrected below. (Now have a 360 bearing on my f355)
    Cole_ve likes this.
  7. m.stojanovic
    m.stojanovic F1 Rookie
    3,313
    Serbia - Niš
    Miroljub Stojanovic
    So, for the price of two (non-available) 355 hub-bearings, one can get fifty (50) hub-bearings for Ferrari 360 from Alibaba (Automotive Bearing For Ferrari 360 Challenge Rear Wheel Hub Bearing 179070 Auto Spare Parts - Buy Automotive Bearing For Ferrari 360 Challenge 179070,For Ferrari 360 Challenge Wheel Hub Bearing,For Ferrari Auto Spare Parts 179070 Product on Alibaba.com), custom made with a deeper dish to suit 355 and get some discount for the units to be supplied without the ABS sensor ring.
  8. Johnturbo
    Johnturbo Rookie
    Feb 10, 2023
    32
    John Robinson
    #308 Johnturbo, Nov 4, 2024
    That company would almost certainly make those TWO (I found another one, as above) machining changes wouldn't they?
    The quality won't be SKF but the question becomes vs "used" SKF.
  9. Johnturbo
    Johnturbo Rookie
    Feb 10, 2023
    32
    John Robinson
  10. 05elise
    05elise Karting
    Jul 20, 2011
    214
    Sharpsburg, GA
    Dan
    I have machined one of the 360 hub bearing units to F355 dimensions now too and it is a fairly easy job. The only downside is these will only work for the front hubs.
    Now, I am looking into the possibility of finding a hub bearing unit that could be modified to fit the F355 rear hub carrier. Do any of you have an old, junk, failed F355 rear hub bearing unit laying around that you would be willing to send to me? I just need it for measuring its dimensions so it does not need to be a serviceable unit.
  11. Johnturbo
    Johnturbo Rookie
    Feb 10, 2023
    32
    John Robinson
    I'm glad that info was useful to sombody.
    I've eyeballed photos of various rear hubs and not seen anything that looks quite right so far. Keen to hear if you get anywhere with it.
    Cheers,
    05elise likes this.
  12. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    489
    London
    Steve C
    I have one but I'm in the UK - which measurements do you need?
  13. 05elise
    05elise Karting
    Jul 20, 2011
    214
    Sharpsburg, GA
    Dan
    I need the hole spacing for the mounting bolts to the carrier. The diameter of the hub housing where it fits into the hub carrier. The distance between the mounting face to the carrier and the hub face where the brake disc is bolted. The thickness of the splined inner bearing race and the depth from the edge of the wheel centering protrusion to the face where the axle nut tightens down.
    It's really best if I have one and can set it on my surface plate and use my machinist's measuring tools to get the precise measurements. I would be willing to pay the shipping to the US if it isn't too cost prohibitive.
  14. Johnturbo
    Johnturbo Rookie
    Feb 10, 2023
    32
    John Robinson
    I have the means to measure all that alternatively. (Started my career with a brief stint as a Quality Inspector - could also model it up in a few minutes)
  15. 05elise
    05elise Karting
    Jul 20, 2011
    214
    Sharpsburg, GA
    Dan
    There is no reason at all to ship it to me then. I would very much appreciate you getting all those measurements for me and modeling it up is even better. Thanks!
  16. Johnturbo
    Johnturbo Rookie
    Feb 10, 2023
    32
    John Robinson
    Certainly happy to do that (also happy to ship it back if necessary).
  17. 05elise
    05elise Karting
    Jul 20, 2011
    214
    Sharpsburg, GA
    Dan
    Thanks again!
  18. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,194
    So. CA & NV
    Peter
    Anyone have the ATE part number for the clutch master cylinder? I'm sure it's a standard part used on other vehicles.
  19. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,466
    Los Angeles
    f355spider and Carmellini like this.
  20. phrogs
    phrogs F1 Veteran
    7,370
    Kzoo Michigan
    I just tried my local BMW dealer and they told me there are none in stock in the USA.
    I looked at the ones I have and they have a Mercedes Benz emblem cast in it
    Does anyone have any leads on these even aftermarket. Or I guess I could try to make some myself
  21. redwedge
    Sep 30, 2012
    489
    London
    Steve C
  22. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    There is a Z-Shaped Heater hose that runs from the water pump neck to the heater connection on the firewall of the 348. It is the circled hose in this set of silicone replacements.
    On my recent major, I decided to change this hose because it is somewhat difficult to access later. My local parts store found me a very good rubber replacement option. ACDelco Part 16135M. It's not a perfect match but it's close enough.
    05elise likes this.
  23. Ferrarista98
    Ferrarista98 Formula Junior
    299
    Jason L
    Anyone know of a replacement part for the steering rack bushings or for the fuel line clips that hold the lines separate near the front of the engine bay?
    Steering rack bushings 137527 and 137528
    Fuel line clips 160675
  24. Shacklock
    Shacklock Rookie
    Sep 18, 2023
    15
    Gary Shacklock
    ALTERNATIVE FOR VACUUM SOLENOIDS - 159177
    Hi Guys,
    Ive just replaced both of my Vacuum Solenoids (part number) 159177. These control the Exhaust Valve and the Secondary Air Injection stop valve. I found an identical solenoid under Ford part 6580879 (see https://www.leadercomponents.com/product/lsc-6580879-genuine-ford-egr-control-valve-new/?srsltid=AfmBOooioya7kpaRArLr46L51XPgwo1lkPNFa-L9bTqt8JrXwVXMtqc3). I actually purchased one Ferrari original and one Ford item. I bench tested them and can confirm they are identical.
    RED HEAD and Qavion like this.
  25. Ferrarista98
    299
    Jason L
    this is awesome thank you so much! I was just about to go through this system as I don’t think my valve is working properly. Appreciate the info, post, and testing. This is what this community is all about.
