355 - F355 / 355F1 Parts Thread | Page 14 | FerrariChat
355 F355 / 355F1 Parts Thread
Discussion in '348/355' started by CRAIGF355, Aug 7, 2011.
  1. Shacklock
    Shacklock Rookie
    Sep 18, 2023
    15
    Gary Shacklock
    No problem. After 18 years of having my exhaust value wired open everything is now working. For those with a rattling bypass valve I found that putting a small tension spring on the actuator arm pulling at a right angle away from the valves up/down travel really helps. Make sure you have a steady vacuum out of the bean tin. I had to replace both of the small check valves and the. I’d get a steady 10-15 in hg on startup and 55 in hg after a quick run
  2. Qavion
    Qavion F1 World Champ
    14,627
    Ian Riddell
    Hope it's a genuine Ford part. I see Ali Express is selling some for less than U$10
  3. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    492
    London
    Steve C
    I've had two PartsTec PTA510-0549 on the car for a while now, working fine. £14 each. I don't think it's a risky area to fit a cheaper part and they are essentially so ubiquitous as to be commoditised.
    Qavion likes this.
  4. Johnturbo
    Johnturbo Rookie
    Feb 10, 2023
    33
    John Robinson
    I posted a couple of other Ford part numbers up there ^
    Must be a few!
  5. redwedge
    Sep 30, 2012
    492
    London
    Steve C
    Ferrari turn signal relay 158019 (superseded by 170762) is the same as Alfa Romeo 60693732. Here in the UK, £25 from an Alfa Romeo shop instead of £150 for the same part from Ferrari.
    blox79 likes this.
  6. robcarter
    robcarter Rookie
    May 15, 2009
    6
    Worcs (GB)
    Robert Carter
