355 - F355 5.2 and tubi test pipe ( cat replacement ) | FerrariChat
355 F355 5.2 and tubi test pipe ( cat replacement )
Discussion in '348/355' started by bennzwel, Nov 26, 2021.
  1. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    I have a 96 355 5.2 with original cats and the old style tubi muffler.
    To get more rumble at low RPM and higher pitch at higher RPM someone suggested to replace the cats with Tubi straight pipes ( and the emulator to eliminate warning lights )
    Could someone confirm replacing the original cats with Tubi pipes make the noise different ?
    Would there be lot of fuel smell when cats are removed ? Any risk or damage to the engine ?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,541
    San Carlos, CA
    Mitchell Le
    You will ...
    get a very rich smelling exhaust ...
    a very much louder exhaust note ... even then the bypass valve is closed
    and a constant bother of CEL
    Some 355 (especially 2.7) do not run well with cats removed. They rely on a bit of back pressure in the exhaust to run right.
  3. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    I thought with this specific Tubi on 5.2 you don’t get the CEL. Isn’t it the case ?
    So it is better to not touch the cats and just replace the muffler ? I’m thinking to get a Nouvalari SS to replace the old tubi on the car
  4. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    First I've heard of this (which is not to say it isn't real). Why don't 355's with free-er flowing mufflers have similar problems? Can you elaborate on what you mean by they "do not run well"?
  5. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    yes the car runs better with stock cats or high flow cats.
    ive run all the configurations. including straight pipes. and car runs better with cats.
    to answer OP question. yes you will have strong exhaust smell. i ran straight pipes for two seasons and couldnt take the smell anymore.
    so put the stock cats back. and the car idled and smoother.
    i am running a Nouvalari SS right now.
    i think it’s the perfect in between balance. and a fair price point
  6. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    Oh that’s great !
    Do you have any recording of your car’s sound ? Is your 5.2 ? Any issues with the quality and fit ?
  7. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    yes i have a recording. i can send to you by what’s app. what’s your number.
    no issue with fitment/quality. the nouvalari is a good exhaust.
    yes my car is a 1997 5.2.
  8. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    my current setup right now. and has been the best balance since owning the car almost 8 years.
    ive done everything:
    stock headers
    fabspeed headers
    stock cats
    hollowed cats
    straight pipes
    stock ypipe
    Nouvalari catless ypipe
    stock exhaust
    Challenge fabspeed exhaust
    Nouvalari SS exhaust.
    my current configuration i feel best balance.
    Fabspeed headers
    Stock cats
    Pepsi10 likes this.
  9. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    What’s the difference between stock cats and catless ypipe on your setup ? Is the ypipe after the cats and removes the exhaust flap?
  10. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    the ypipe is on top.
    it’s what connects to the bypass valve.
    so when the bypass opens, most of the exhaust passes through the yipe.
    so i’ve found a good balance to have stock primary cats below. and then the catless ypipe above.
  11. ducrob
    ducrob Formula Junior
    Nov 20, 2011
    749
    Canada
    Rob
    I put a full de-catted Fabspeed system on my 5.2 Spyder. I should have kept the high flow cats on the car….when I would fire up the car in the parkade, the exhaust fans would go on (to exhaust the parkade) and this always pissed off the building management. Also, the exhaust stinks. Engine light was always a problem too although I was very happy with the Fabspeed product. With top down, it was a little too loud on longer trips. Funny….I still have all the cats and original headers/exhaust…I should sell them. Cheers.
  12. yelcab
    Nov 29, 2001
    13,541
    San Carlos, CA
    Mitchell Le
    De-catted 5.2 (or 2.7) 355 is asking for all kinds of issues, of which CEL is one.
  13. Qavion
    Qavion F1 World Champ
    14,251
    Ian Riddell
    +1
    It made my eyes water, too, when standing near the vehicle. I switched to high flow cats.
  14. ducrob
    Nov 20, 2011
    749
    Canada
    Rob
    I knew I would have an engine light going in when I purchased (same with any de-catted brand). A piece of black electrical tape eliminated that;). I would purchase Fabspeed again and always recommend the product, it’s artwork.
  15. tres55
    tres55 F1 Rookie
    3,571
    Canada
    Personally I think they sound a bit more refined with high flow cats as well.
    I had test pipes on my F1 355...it was stinky for sure. Great rumble though.
    With high flow cats, you lose the rumble but when you're on it, it sounds cleaner IMO. Added benefit of not needing to shower after every drive.
    MAD828 likes this.
  16. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    Before the 1980's no cars had cats and somehow everyone was able to drive them without going blind or needing to shower.
    GTO Joe likes this.
  17. ShineKen
    ShineKen F1 World Champ
    19,870
    Southern California
    Nostradamus
    Both my 2.7 355's ran/run fine with primary straight pipes. Never ran cats, so don't know how it runs with primary cats, but I believe @INTMD8 documented a 10-15 rwhp gain from 200 cell cats to straight pipes (on 2.7). An additional 10 rwhp gain from OE catted Y-pipe to customer de-catted Y-pipe.
  18. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    I removed the cats on my 5.2 a couple of years ago and think it was the greatest improvement the car has ever had.
    I installed mini-cats on the rear O2 sensors so no CEL.
    In the summer you really notice how much cooler the engine bay is.
    The only thing you have to do is go though the re-learn process for the ECU.
    Pepsi10 likes this.
  19. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    What mini cats did you use ? And what exhaust you have now ?
  20. bcar1
    bcar1 Karting
    Aug 2, 2017
    224
    NYC
    Bob
    I have Larini primary and secondary cat deletes on a 5.2 car with a capristo. I do not notice the exhaust smell issue at all- I think I would notice it, no one who has ever seen the car has commented either. The car is slightly louder than I’d like with the valve closed but I think sounds better than it did with race cats and It is perfectly driveable at highway speeds. The car has 90 deg mini cats from fabspeed but they do not prevent the secondary 02 cels. I have not spent a lot of time playing with them so it’s possible this is solveable but most people I have spoken to told me
    It’s unavoidable. The car shoots flames on high rpm upshifts- not necessarily a reason in itself to make the change but does not hurt :).
    ShineKen and tres55 like this.
  21. tres55
    tres55 F1 Rookie
    3,571
    Canada
    Life expectancy is a lot higher these days. :D
    Targatime likes this.
  22. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    More like before the mid 70's. All these ******* (;)) ranting about smell and watering eyes would never have made in back in the 60's muscle care days. Cars running trips and dual quads were so rich you could light the exhaust with a match. That's the way they built them back then. And then we'd but bigger jets int he carbs just 'cause. :)
  23. johnk...
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    Hey, I'm still kickin' around. :p
  24. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    Then it’s better to either get sport cat or leave the factory one in place for 5.2?
  25. yelcab
    Nov 29, 2001
    13,541
    San Carlos, CA
    Mitchell Le
    I think most of us would think Sports cats are better for sound.
    bennzwel likes this.
