355 - F355 5.2 and tubi test pipe ( cat replacement ) | Page 2 | FerrariChat
355 F355 5.2 and tubi test pipe ( cat replacement )
Discussion in '348/355' started by bennzwel, Nov 26, 2021.
  1. bcar1
    bcar1 Karting
    Aug 2, 2017
    224
    NYC
    Bob
    I think the factory’s have ceramic cores and have the potential to crack/block/overheat. My understanding was the all metal options from a couple vendors out there are the safest/highest longevity option.
    bennzwel likes this.
  2. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    If I Only replace the Ypipe with a catless one, would I get any warning lights on a 335 5.2 ?
    I am thinking to get Nouvalari Catless ypipe
  3. ShineKen
    ShineKen Two Time F1 World Champ
    20,223
    Southern California
    Nostradamus
    Not a 355, but for my Scud, I switched from 100 cell HJS cats to straight pipes and the sound changed marginally. Perhaps a 15% bump in volume, that’s about it. Straight pipe still sounds cleaner, but not by my much.
    I mention this because most Race cats for the 355 are 200 cell. Perhaps a happy medium is 100 cell cats and maybe HJS brand, since they are known to flow well.
    Fabspeed or Kline can build 100 cell HJS cats for the 355.
    100 cell will still give CEL issues unless you get really creative. 200 cell might not give CEL.
    bcar1 likes this.
  4. bcar1
    bcar1 Karting
    Aug 2, 2017
    224
    NYC
    Bob
    my experience is a little imperfect because I was randomly getting a 1448 before I switched to catless y, but it should not generate a code bc high rpm exhaust gas should generate enough heat to easily trigger the probe.
  5. bcar1
    bcar1 Karting
    Aug 2, 2017
    224
    NYC
    Bob
    my 200 cell hyperflow threw a code, 02 extenders+ steel wool solved it though.
    ShineKen likes this.
  6. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    So Tubi itself doesn’t offer any solution to eliminate the CEL light when using their bypass pipe on 5.2?
    I’m deciding what’s the best and cheapest way to get a better exhaust with the factory cats, Ypipe and first gen Tubi muffler . I thought doing straight pipe will get rid of old and worn out cats and reduces some load on the headers . Is this the right assumption ?
  7. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    Could you share the details on o2 extender and steel wool you mentioned ?
  8. bcar1
    bcar1 Karting
    Aug 2, 2017
    224
    NYC
    Bob
    https://www.modusperformance.com/products/o2-oxygen-sensor-extender-spacer-extension-m18x1-5-hho-bung-1-75-usa-02-cel-fix?variant=39293698769078&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=EAIaIQobChMIqJrompSg9QIVyMqUCR202Qr4EAQYEyABEgKyFfD_BwE
    Something like this, a straight spacer with pretty rough grade steel wool like single 0. These worked with a high flow cat that was causing cel.
    I tried 90 deg fabspeed mini cats w my test pipes- but they did not work consistently.
    https://www.fabspeed.com/universal-o2-spacer-with-catalytic-converter-single/
    My next move was to replace the 02 sensors because the wires were pulling at the plug but I learned to live w the cel and just check it every few hundred miles.
  9. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    Thanks ! How do you use the steel wool ?
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,705
    San Carlos, CA
    Mitchell Le
    You scrub the outside of the extender until they are shiny. Everyone knows that a shiny car works better.
    OK, just kidding. You stuff the inside of the extender with a small amount of steel wool so that the overall air volume of the thing is smaller.
    bcar1 and bennzwel like this.
  11. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    Wouldn’t the steel wool burn up eventually or it will last for number of years ? Is it just the standard wool you can buy from hardware store ?
  12. yelcab
    Nov 29, 2001
    13,705
    San Carlos, CA
    Mitchell Le
    I like to see you make steel wool burn up .....
  13. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
  14. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
  15. Qavion
    Qavion F1 World Champ
    14,682
    Ian Riddell
    The type you provided a link to comes with a small piece of cat material. It does the job of the steel wool.
    A lot of folks recommend Big Daddies Garage. They are the steel wool type and contain (quality) steel wool already:
    http://www.bigdaddiesgarage.com/angled-cel-fix.html
    For use at the post-cat position only.
    bcar1 and Skippr1999 like this.
  16. Qavion
    14,682
    Ian Riddell
    Ah, Ben... are you in New Zealand (Wellington)? It may be simpler/faster to go with the NZ product.
  17. bennzwel
    bennzwel Karting
    Nov 30, 2018
    111
    B N
    Yes indeed . What would be a local product ? Happy to consider all options including a local supplier of test pipes with stock availability and good prices
