F355 5.2 motronic Electrical problem | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by Jan Van den Bosch, Apr 16, 2024.
  1. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
  2. Qavion
    Qavion F1 World Champ
    14,512
    Ian Riddell
    If you have a car with as many problems as mine, then you'll understand :p
  3. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    Ok you're Aussie ! Super, i have a Logistics an tranport company, i can say you guys have the greatest trucks in the world! Anyway I think if it runs it is the most fun car in the world! It puts a Smilde on my face everytime I drive it :). It sounds like nothing else. Just visited the topshop this weekend
  4. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
  5. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    My outher bundle of joy! :)
  6. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    Eureka ! he is running!!!!! all thanks to You Man!
    now next issue :) my gauges are not working, rpm oil pressure en all of this, light ok indicators are ok, turn signal check engine all good.
    speedo- Tach - oil pressure fuel level ... any ideas?
  7. Qavion
    14,512
    Ian Riddell
    Do all of your warning lights work? e.g. airbag (on startup), suspension setting (normal/soft), brake warning (!) and seat belt? If not, check fuse 24.
    If you removed and reinstalled your instrument binnacle, I assume you reinstalled all 5 connectors. Is your speedo and tacho illuminating when you turn on your lights?
  8. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    The illumination on the speedo and tach are working. Warning lights are comming on and off if i turn the key to start the engine. I'll make a short video so you can see and check if it is normal like it is now. If i check the wire signal from the ECU is getting to the dash. On pin 12 of connector 41052 i get 12volts with no engine running and it goes down when engine running to 6.3volts and drops to 5.6 volt if axellerator is pushen. It givs signal to dash on rear connector on the dash. Earth is ok , on plug E on the dash pin 3. Signal is getting to that point from ECU. I dont know what voltage I should mesure.. but the voltage is the same on the ECU side and the dash side.
  9. Qavion
    14,512
    Ian Riddell
    So you mean the tacho signal.
    Unfortunately, it sounds like a power wiring/splice issue (especially if all the warning lights are working). And as mentioned previously, Ferrari doesn't tell you where their splices (pigtails) are.
    Figure 5 shows the power wiring (green/white VB). Splice 30048 could be damaged (open circuit). If it's a short circuit, I would imagine you would have a lot more issues.
    Euro 5.2 diagram here:
    https://www.dropbox.com/t/FvzCJoWTpd5KLeve
    Does the oil temperature gauge on your central instrument cluster work?
  10. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    Forget last message! Its fixed!! A F*cking fuse was bad!
    Exept from te sport suspension button ( was not workin before ) it used to work ... different problem! Tomorow rebuilding the rest of the parts en drive the snot out of the thing!
    Qavion likes this.
  11. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    Hi Qavion, problem fixed! i didn't dubble check the fuses , a 10amp was bad , now everything seems to work :) .
    the suspension did stop working befor i had the short, any idea where to look for the problem?
    again I can not thank you enouth for all the help!
    Qavion likes this.
  12. Qavion
    14,512
    Ian Riddell
    Not many clues here :p
    The system can be affected by that fuse, but if you say it happened before, we’ll have to look elsewhere.
    The usual suspects are:
    Broken toothed wheel on top of one of the 4 struts
    Broken plastic parts in actuators (see CaptainZ CNC website for pictures of broken parts)
    Vertical accelerometer behind front bumper. A short in this has been known to blow fuse 24. There is a metal cube inside the accelerometer which becomes dislodged if you go over a pothole or something. It falls onto the internal circuit board and causes a short circuit.
  13. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    i'll take a look, this is not a mager issue, i don't use the button enyway. would be nice that it works,
  14. Qavion
    14,512
    Ian Riddell
    Is the fault light illuminating or is the soft suspension light not illuminating when you move the switch ?
  15. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    I would like to do something for you! do you like beer?? I live in Beer and chocolat land :) else I send You a giftbasket for you're help
    flash32 and Qavion like this.
  16. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    it just doesn't light up, no faults
  17. Qavion
    14,512
    Ian Riddell
    If you turn on the ignition/start the engine without moving the car, the suspension fault light sometimes illuminates. Just go for a drive to clear the fault.
  18. Qavion
    14,512
    Ian Riddell
    Sorry, cross-posted. If the soft suspension light doesn’t come on, it could just be the switch. It’s wired directly to the light.
    If the fault light is on, the suspension system defaults to the hard setting (sport)
  19. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    Can I use an outher switch of in the cab to test this?
  20. Qavion
    14,512
    Ian Riddell
    Rear fog light, or other dual position (latching) type.
  21. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    top, i'll try that
  22. Qavion
    14,512
    Ian Riddell
    Careful not to break the plastic frame around the switches. I usually disassemble the gearshift gate and push the switches from behind.
  23. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    hi Qavion,
    new problem, my side window switch box died part nr 79534 - 154769 under dash,
    do you know if there is an alternative fiat or alfa witch is the same?
  24. Qavion
    14,512
    Ian Riddell
    How did you determine it was dead?
    I haven't heard of any alternatives, but perhaps they can be repaired (although the master chip may be Ferrari-only)
    Spider version shown:
    Why are there splices on these wires?
    I would have thought that the left and right sides would be independent (since there are two fuses), but looking at the components on the Spider board, I'm not so sure.
    Is the plug seated properly? You have to move it sideways to seat it properly.
    Would you be able to take a photo of the internals of your coupe Window ECU?
