F355 5.2 motronic Electrical problem | Page 4 | FerrariChat
Discussion in 'Technical Q&A' started by Jan Van den Bosch, Apr 16, 2024.
  1. Qavion
    Qavion F1 World Champ
    14,023
    Ian Riddell
    It's interesting to see that second hand Spider Window ECUs are sometimes half the price of GTB ECUs. I wonder if they interchangeable (Spider -> Coupe)?
    I assume if there are no inputs from the Spider microswitches, the Spider ECU would behave like a normal ECU. The wiring is the same on the main plug. The Spider ECU has a second plug.
    I would have to check the inputs on my Spider to confirm this.
  2. Qavion
    14,023
    Ian Riddell
    Looking at the Roof diagram, you might have to short out at least one pair of pins on the Spider ECU's additional plug to simulate roof latched closed.
    I'll disconnect the additional plug on my car to see if the windows work.
  3. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    i'll try to open it, and see what is inside.
    the pins you see on the pic is left and right that way i could test bouth sides.
    electric motors are fine, i think the power is not getting to the left side relays, purhapse a line broke inside.
    thanks for the tip!
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,453
    San Carlos, CA
    Mitchell Le
    JVDB, when are the problems going to stop?
    Qavion likes this.
  5. Qavion
    14,023
    Ian Riddell
    The windows on my Spider work fine without the Window ECU top plug in. I'm pretty certain from this that the Spider Window ECU would work on your car.
  6. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    Nearly there! Only the windows to go and ... sport suspension button but then i'm good i hope
    Qavion likes this.
  7. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    I think that there may be a problem with the 12v not getting tonthe ecu for the side that isnt working
  8. Qavion
    14,023
    Ian Riddell
    From your first message, I assumed both windows weren't working. Did you check the fuse?
  9. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    Yes i did , ill check the wire that is entering the ECU on the plug one has power so and i think the second one, going to the other side of the car ( door) isnt. May be an fuse box problem or something else... purhapse i just bridge the power wire thats working on the ECU to the other side that isnt. Just use one window at the time worst case
  10. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    Just tought about something,
    By a Porsche !
  11. Qavion
    14,023
    Ian Riddell
    Unfortunately, there are no inline plugs between the fusebox and the ECU, so it has to be either wiring or the fusebox which is causing no power.
    For reference:
  12. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    Hi Qavion,
    normaly i'll check the plug soon to see whats up,
    an outher issue i found is that my high beam lights dont work when the runninglights are on,
    if ther are no lights on the high beams work,
    if the running lights are on they dim when i put on the high beams,
    looks like the high beams short when i put them on together with the lowbeams. do you have a wiring diagram of the lights? :)
  13. Qavion
    14,023
    Ian Riddell
    Euro 5.2 diagram here:
    https://www.dropbox.com/t/PxKbWb5wcqebbGir
    How do you get your high beams to work without the running lights being on? Do you mean your daytime flashers operate (in the bumpers)? When you turn the knob, you have to pass through the running light setting to get to low beam headlights, then you push the steering column stalk forward for normal high beam headlights.
    On USA cars, the low beam headlights are turned off when you turn on the high beam headlights. However, they shouldn't turn off or dim the sidelights/running lights. Euro cars have a different E (E2) relay and use provisional wiring to keep the low beam headlights running during high beam operation.
    When you turn on the low beam headlights, this activates relay A (E5) as well as relay D (E13/headlight pod motor control). Relay A stops your daytime flashers operating.
    I can't think of anything at the moment which would cause the high beams not to work with the running lights on because the steering column stalk switch contacts normally won't allow this.
  14. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    hi Qavion,
    update! windows are fixed :) bad plug ...
    just the lights to go!
    Qavion likes this.
  15. Qavion
    14,023
    Ian Riddell
    Which one?
  16. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    it was bad connenction on the red/white wire on the big plug nothing mager.
    simpel fix, do you know if there should be a blue light comming on on the dash when i use the highbeams?
  17. Qavion
    14,023
    Ian Riddell
    Yes. In the luggage compartment fusebox, there is a branch off the #11 fuse (L/H high beam). Power goes from the fuse to the headlight and to the bulb in the dash.
  18. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    strange i checked the fuses ..
  19. Qavion
    14,023
    Ian Riddell
    Maybe a bulb or wiring issue?
  20. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    i think there is a short somewhere, the headlights dim when i use the highbeams, like the power is on the ground of the high or lowbeams when used.
  21. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    perhapse idd a bad bulb witch causes this fenomenon
  22. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    i'll check them to make sure
  23. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    I'm still impressed that you look like an F355 Encyclopidia :)
  24. Qavion
    14,023
    Ian Riddell
    Or maybe your battery is just getting low :D On our cars, the low beams and the highbeams illuminate at the same time.
    Or maybe relay A (E5) is not working and your daytime flashers are illuminating instead of your high beam headlights? Are you actually looking at the lamps when you are testing them?
  25. Jan Van den Bosch
    Jun 10, 2019
    55
    Belgium
    Jan Van den Bosch
    no i just did not test them in the workshop still got to do this,
    i'll keep you posted
