F355 A/C Relay advice please | FerrariChat
Discussion in '348/355' started by Gottaloveit, Jan 28, 2014.
  1. Gottaloveit
    Gottaloveit Karting
    Jul 12, 2012
    52
    Simple advice needed - where the hell is it ?????
    Jiggered if I can find it in the manual.
    Thanks,
  2. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    #2 348Jeff, Jan 28, 2014
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Kinda cool solution thanks for sharing. What kind of a fuse and how does it connect. Some of us with f1 have a relay that fails closed and causes the pump to stay on and potentially burn out. Some of us have replaced with one that blows open but then your stuck with not transmission might be a good option for us.
  4. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    Its a direct replacement for a blade fuse and comes in all sorts of ratings. I bought mine in UK but sure someine in US will sell something similar
    ETA Series Motorsport/Car 1610 Circuit Breaker -Designed To Replace Blade Fuses | eBay
    The little tab pops up when it triggers then you can just push it down (after curung faul of course!).
    BTW I had the common melted fuse problem and after replacing it with this it triggered a couple of times usually after the aircon ghad been running for bout 15 mins. I toook both the relays out and gave the contacts a good clean with wet/dry and contact cleaner and then put them back. Its never triggered since :)
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,672
    San Carlos, CA
    Mitchell Le
    On my 348, that fuse burned up in a small little fire at the end of the engine out service while the AC was being recharged. Made for a nice little surprise. Clean out the contacts.
  6. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    Perfectly normal....where do you think the heat comes from for the heater?! LOL ;-')
