F355 Airbag Light | FerrariChat
F355 Airbag Light
Discussion in '348/355' started by sporlan, Aug 14, 2011.
  1. sporlan
    sporlan Rookie
    May 18, 2011
    9
    I am wanting to reset my airbag light. I looked in the service manual and found where you ground out the terminal 1 on the diagnostic plug. I opened the access door for the passenger floor board fuse panel. There are two plugs. Anybody know if it is the blue or yellow plug?
    Thanks.
  2. Moopz
    Moopz F1 Veteran
    5,558
    Orlando, FL
    Paging Dr. Taz...
  3. sporlan
    sporlan Rookie
    May 18, 2011
    9
    I figured somebody had done this??
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Got me here, currently my car is in boxes
    Yellow wire harness is the color code for the airbag circuit. I would not chance jumping anything yellow without an instruction manual. The correct way is with a connector with leads that you plug in, then the wires jump the circuit. One wrong jump on an airbag circuit and you can cause great damage. I do not recommend taking a chance.
  5. Dino355
    Dino355 Rookie
    Nov 5, 2007
    44
    Wimbledon England
    Dean
    But if you do find out I also have an airbag light due to starting the car with the dash removed to get it out of the rain, which is strange as it hardly ever rains here in the UK...
    Dean
