F355 alarm Help | FerrariChat
F355 alarm Help
Discussion in 'Technical Q&A' started by jadbardawil, Sep 30, 2013.
  1. jadbardawil
    jadbardawil Rookie
    Sep 30, 2013
    2
    Lebanon
    Jad Bardawil
    hello,
    I have a purchase an F355 one year ago,
    two months ago i tried to change the battery of the remote control (black) the led fell down, i installed it back again, the car won't open.
    the problem is:
    i have only this remote that doesn't work,
    i have no pin code (the dealer couldn't get it from Ferrari, Italy also)
    any suggestions?
    please help!
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,692
    South East
    Jimmie
    Eric355 or Gobble may be able to clone you new fobs - they should be along to answer soon - if not the problem is many $$$ sadly
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,575
    Charleston, SC
    Curt
    When you ask for technical help, you should put in as much informaiton as possible about your car. What year? Is it an aftermarket alarm? take a picture of the alarm FOB and post it here, etc.
    The early cars 95 or so IIRC did not have an alarm system. The 97's and later did. This system is similar to the 360's alarm, which itself is similar to the porsche 993 alarms of the vintage. If its an aftermarket alarm.. good luck. Have no idea.
    If it's the later alarms with the black FOB as the 360.. I have no clue where the LED is in the FOB that could fall out. Did it fall of the circuit board? There should be two metal contacts for the battery. Clean them and then put a new battery in. They should have a "+" on the circuit board. Align this with the battery. I've dropped my fob many times and it should survive a fall from hip height. You may also have to press it multiple times to get the alarm synchronized again.
  4. tazandjan
    39,266
    Jad- Even if you broke the fob, Eric355 (southern France) should be able to copy the contents of the EEPROM in the fob to a working fob. He may even be able to repair the original at the same time. Send him a private message and see what he says.
    Your other option is to buy a complete alarm kit, which includes a new Alarm ECU and three matching fobs with a new PIN and that PIN already programmed into the new ECU.
    Recommend getting a leather case for whatever fob you eventually use. Cushions the blow if you should happen to drop it. I have one for each of my 3 fobs.
