F355 Alternator Problem Solved! | FerrariChat
Discussion in 'Technical Q&A' started by AZLambo, Aug 30, 2006.
  1. AZLambo
    AZLambo Formula Junior
    Nov 4, 2003
    511
    Phoenix, AZ
    Jeff
    Well, After many trials and tribulations with my alternator woes, I had the local Ferrari dealer do my car's second major service, since it was due anyway, and while doing so, they replaced the charging system's wiring. Well, everything is working correctly now. There must have been an "open" wire somewhere that would flare up after driving a little while that would make the alternator stop charging, or overcharge in the case of another alternator I installed.
    Anyway, thousands of dollars later, it's fixed!
    AZFerrari
  2. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Well, at least the car is working. I think we all were hoping it wasn't a hidden wire but alas that seems to have been the case. I can't even imagine how many hours of labor that took...
    Ken
  3. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    Reminds me of the problems I was haveing with my home alarm.
    All wiring tested perfect. Every day the alarm would go off for no reason. Tested every sensor and magnetic switch, checked continuity of all the wires.
    Did this four or five times during the month, everything check out perfect but still the alarm would go off once a day.
    Finally determined what the problem was... When the alarm went off it was always in the afternoon... gave a clue. Seems the heat of the sun would warm the west wall of the house. When the house was constructed one of the nails that held the siding on the outside wall semi penetrated tthe wires of one trigger and when heated opened the cuircuit thus triggering the alarm. When the wall cooled down in the evening and in the morning, everything was fine. Ran new wires and no more problem, but it drove me crazy fo a long time. Had the alarm people out three or four times. They couldn't find anything wrong. I found it by accident by accidently knocking the wall while moving a sofa!
    Glad to here you solved your problem!
    JD
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Heck of a deal!
    Mystery problem. Mystery solution.
  5. f355spider
    f355spider F1 World Champ
    18,055
    Get the old wiring harness back and inspect it. Nothing like a little forensic anaylsis.
  6. Rifledriver
    37,288
    The B+ cable from the junction block over the top of the motor to the alternator is too small a guage. I have replaced several that were cooked and discolored almost their entire length from overheating due to too high a load for the cable size.
    I have been making them from welding cable of a larger gauge.
    The job can be done with the motor in the car but is a little time consuming because the cable has to run the length of the valley of the motor under everything and then down the front behind the timing belt and cover on the right side of the motor. It is something every 355 will face at some point. It is also covered with a light weight version of Aeroquip Firesleeve the entire way.
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Glad to hear to got it sorted out. Electrical problems are the biggest pain in the neck to solve.
