F355 Berlinetta 1997 insane overheating | FerrariChat
Discussion in '348/355' started by Mats Andersen, Jul 22, 2018.
  1. Mats Andersen
    Mats Andersen Karting
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Hi..
    Just as i got my new car sorted. I 20 min drive with my wife, then after a second gear pull to the redline the water temp very rapidly soared up to red lamp maximum levels. Pulled over as waited for a while, tried again and the same happened.
    Got picked up by rescue truck. back in the garage. what to do.
    On thing is for sure, it has nothin to do with fans. car was at speed and plently of air. Even at no throttle and 60mph temperature rapidly increase. Oil temp normal. No warning lights. idles as before and runs on all cilynders. No strange noises.
    I know its not faulty gauge because I could hear the water boiling behind me as I stopped the engine.
    I think that the circulation must have stopped. Beacuse it the water was still going around through the radiator it would have been able to cool it.Either water pump or thermostat.
    Water pump is just replaced on last service not long ago. Is this normal failure on these cars???
    Mats
  2. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Mats,
    Sorry to hear. Agree sounds like circulation if levels are ok. Sounds either pump fail or fail to operate from thermostat. No doubt experts along soon. How many miles since water pump replaced?
  3. S-T48
    S-T48 Formula Junior
    575
    Stevenson Ranch, CA
    Unrelated to overheating but as a result, your head gasket may be toast now.
  4. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Ok that might be or not. no indication of that as of yet.
    water pump replaced 1000kms ago
  5. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Thermostat works....
  6. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    And pump belts, bearings seem ok from exterior?
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,244
    CT
    John Kreskovsky
    If you are over heating that badly I presume coolant is being expelled out the over flow? What is the reading on the coolant temperature gage? Was it properly bled?
  8. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Belt works. I did not fill it or bled it but now I have bled it after many times at the thermostat housing. After I took out thermostat for test i boiling water. Radiators does not get properly warm. Every now and then the right radiator starts but only cold air can be felt coming out so I assume there is some hot water reaching the sensor but it doesnt go down into the radiator.
    Pipes that goes out from tvermostat and Y to each side gets very hot maybe a very slight sirkulation push this water barely enough to trigger the fan switches?
    Any better way of bleeding?
  9. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Temp reading was up to 125 C...
    Some fluid came out but surpisingly little. It boiled like a kettle i the exp tank.
    Whith that low amount of circulation can it be the water pump? Can the shaft inthere somehow disconnect fromthe pulley?
  10. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    since it happened at high revs could the shaft in water pump break?
    I found the right side bypass or circulation hose that goes to thermostat housing to be very bad. rubber rotten on inside. replaced it.
  11. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    I am speculating that even though there was something causing too much work load on impeller it would slip on the belt before breaking..
    M
  12. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,734
    The first thing to look at is a bubble near the impeller--that is was the system properly bled?
    ernie likes this.
  13. phrogs
    phrogs F1 Veteran
    7,348
    Kzoo Michigan
    Radiators could be cloged up.
  14. fatbillybob
    Aug 10, 2002
    29,071
    socal
    A fchater about 2 months ago reported a new 355 wp where the impeller broke. A failure like that could cause the problem you report. If you have this problem it will be the 2nd time in 40 years of wrenching.
  15. Ga68_
    Ga68_ Karting
    Jul 16, 2017
    71
    France
    Gaetan
    Hello, it is possible that the purge is not correct, is that there is still air in the system.
    ernie likes this.
  16. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    I did not di a complete purge just vacumed out enough so I could remove thermostat.
    I have bled many times on the bleed bolt.
    Seems like there is no circulation. Even with some air here and there I believe rhere would be circulation allthough not opti al perhaps
  17. A348W
    A348W Formula 3
    Jun 28, 2017
    1,847
    North Wiltshire, UK
    sounds like it could be:
    - failed thermostat;
    - failed impeller (although all of the system should get hot to some degree, there should be no cold bits.)
    - air lock in pipe work.
    - Open the expansion tank;
    - bleed each radiator, is there water coming out and is the expansion tank draining at the same time?
    - re bleed system.
    Best of luck,
  18. A348W
    A348W Formula 3
    Jun 28, 2017
    1,847
    North Wiltshire, UK
    For got to ass, could also be one of the smaller pipes blocked causing an air lock. Recent thread on the 348s with pipes almost blocking so could happen, the two from the expansion tank in particular.
  19. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Thanks I will try to bleed radiators and see.
    Otherwise it will be new waterpump......
  20. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    The (kind of) good news is that if you drain the coolant. So you know you are definitely empty, then you can refill and be sure how much has gone in.
    Whilst empty, are the pump off and inspect. It’ll cost a new gasket, but might show straight away if there is an issue.
    Then of course you get into taking off rads and flushing. Mindful that if you had the pump replaced, could there have been crud in the system that wasn’t emptied and that’s causing a block - or a new pump moved stuff and that got lodged. You really want to be happy that there is no more stuff lurking to block a thermostat etc.
    If one pipe looks poor, probably worth inspecting all. That won’t have helped prevent air locks potentially collapsing tubes and stopping flow?
    It sounds like it is holding coolant, so flow is more the issue. Obviously check fans any way, as a shame to miss something that’s also a (small) part of a wider problem.
    How far away is your Shop? Wonder what role they might want to play in this in case it is related to the pump work.
  21. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Hi thanks. Will proceed and check the things you mention. Where is best way to flush. I see radiators have inlet otlet on top. Is there a drain plug on bottom of rads?
    The shop is far away. They will send a mechanic by plane next week to take out water pump and check. He bring new parts.. so thats cool.
    M
  22. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    Just a thought, if you disconnect the aux heater water pump wires and run the engine with the heater on, if the vents blow cool air then its very likely the water pump has failed. Seems these pumps have a few failure modes. If the pump is required to be replaced it is quite a big job. Best of luck.
    Maranello550, StuR and Qavion like this.
  23. Mats Andersen
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Allright. Only with AC turned on I get got air in the cockpit. With stop button depressed. I only get cold air into car.....
  24. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    Chance of system being clogged is slim. I wouldnt waste time with flushes on a low mile car.
    Always remember that major failures can occur right after parts have been replaced and someone has had the car apart.
    A new part with defects will fail very soon after it was put in and mechanics make mistakes.
    I would be looking at the pump impeller or drive slipping on the shaft under high load.
    DaisyCutter likes this.
  25. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    GT, I get the point, and I don’t think we’re talking years of sludge, but if the pumps off and some pipes are being replaced, I don’t think it’s too much extra effort to check the Rads and make sure everything is clear - which you’d probably have a good idea from draining. Again, I’d be looking at the state of the impeller - did it just bust from poor MFR or fitment - or did anything inside ‘help’. Again, the state of the pipes coming off might help. Conscious it’s not the oil system, but not sure the effort is that huge. Each to their own.
