F355 bursting into flames | Page 2 | FerrariChat
Discussion in '348/355' started by Drock28, Jan 17, 2016.
  1. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    #26 308 GTB, Jan 18, 2016
    Which is why my tech has shielded all oil lines and re-routed them when possible. He replaced one line with a steel pipe he fabricated...
  2. fatbillybob
    Aug 10, 2002
    29,262
    socal
    Be careful of unintended consequences. Solid pipe not properly supported can fail from vibration fatigue. It is a similar problem to soldering a connection vs. crimp in a high vibration environment. That said there is a way to solder and crimp under high vibration as there is a way to using a solid line vs. braided steel one. The problem is more like chess than checkers.
  3. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
  4. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    Nice find.! that was a fantastic overview
    super valuable tip to to keep the nut from that clip pointed away from hoses..
    much thanks to the gentlemen who made the video..
  5. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
  6. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Good video
    My 1995 M2.7 has 2 fuel pumps/filters so does not have the distribution block.
    I think it's a better system
    Why did the 5.2's go to a single fuel pump/filter system?
  7. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    Some 2.7s also had a single fuel pump. Maybe your car was built in 1994 and registered in 95, very early cars had twin pumps IIRC.
    It would seem the twin pumps might be better for engine bay fire safety.
  8. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Terrific video! Who is this guy? Long term owner seems very knowledgeable.
    This should be stickied.
  9. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,185
    So. CA & NV
    Peter
    Great informative video. Heading out to the garage right now to check the placement of the water hose bolt head.
    Obviously someone who is on FChat as he references the forum. It would be great if he would acknowledge himself as he seems to be someone of knowledge and a valuable asset to the 355 community.
  10. TrojanFan
    Nov 17, 2008
    5,185
    So. CA & NV
    Peter
    #35 TrojanFan, Jan 23, 2016
    Good call on this. My recall work on the fuel block was done less than 3 years ago by the then LA area factory shop (they are no longer a factory authorized shop). I just felt the braided hoses and the lower one nearest to the firewall is being worn away by the hose clamp and was worn through the SS outed covering and is starting to wear on the rubber.
    Should this still be a warranty repair to take this to have it fixed?
  11. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Wow Peter! How about that? Can't get my car out from under the lift to open rear but I certainly will.
    Great catch and kudos to the video maker.
  12. TrojanFan
    Nov 17, 2008
    5,185
    So. CA & NV
    Peter
    #37 TrojanFan, Jan 23, 2016
    The white marker in the photo is pointing to the fuel line that is damaged. With the rear deck lid on I can't get in with a mirror to take a better photo to show the actual worn line. These were replaced less than 3 years ago. I suggest that everyone check theirs. I felt around the line and can feel the frayed steel and the wear on the rubber hose underneath.
    I just called the shop and they are standing behind their repair and will replace the line for me this coming week.
  13. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Nice catch
    The repair shop should never have mounted that clamp worm screw in a position to wear away the fuel line.
    They should have known better
    Someone could have died by being burnt to death
  14. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    #39 Drock28, Jan 23, 2016
    can't really see anything from that picture.
    the hose appears to look ok.
    it's wearing on the other side?
    is it wearing on the screw of the water hose clamp like in the vid?
    the point of the recall is to install the bigger block to keep the hose apart.
    unless yours is rubbing against the screw/bolt like in the vid?
    my engine out has just been completed and engine is back in. but car is remaining there for winter so I can't check
    this will be the first thing I ask next time I see my tech.
    but I did get the recall done last year. when I bought car sept 2014 it hadn't been done.
  15. TrojanFan
    Nov 17, 2008
    5,185
    So. CA & NV
    Peter
    Mine seems to be rubbing on the "tail" of the hose clamp which is sticking up, not the bolt. It's on the bottom inside (firewall) of the lower hose. I'll post a photo once it comes back from the shop.
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    ROFLMAO
    @ 2:53 into the video he lets one rip LOL
    One thing he did not touch base on is the lid shocks rubbing the fuel lines also. That also has caused fires
  17. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    #42 Jackie and bill, Jan 24, 2016
    LOL, i think that sound was were he was leaning against the convertible roof tail, it also happend at 1.32 ;)
    Good call on the engine lid shocks rubbing fuel lines, i dint know that. If one was picky, you could also say he never spoke about the re fueling hose splitting..
    Got to hand it to him though, his video has potentially saved a few 355s from fire, thats got to be good. :) After all its taken 20 years for someone to make a video like that.
  18. emac
    emac Formula Junior
    851
    upstate SC
    ernest
  19. Backyard Buddy
    Backyard Buddy Karting
    Mar 8, 2015
    93
    Scary. Thanks for the info.
  20. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Interesting that the recalls purpose was to prevent "some" mechanics from incorrectly installing the water hose clamps. Yet even with the recall done, they can still be problematic.
  21. Rifledriver
    37,288
    You mean installing them the way the Ferrari factory did it before blaming their screw up on independent mechanics? Typical Ferrari BS. Build a car badly then blame the fallout on someone else.
  22. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    The TSB is dated 11/2009. Does that mean it took them 10-15 years to recognize the problem?
    From the looks of my car, the recall gives the fuel lines plenty of room around the hoses. Did the car originally have any clips on the fuel lines?
  23. Rifledriver
    37,288
    No, that was not the first TSB. It means it took them that long to fix it.
    You sound surprised. It is a long standing process for Ferrari. When denials, then verbal blame and finger pointing quits working then written blame takes over. Eventually fixing the problem takes place but not without reminders it was never really their fault in the first place.
    SOP.
  24. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I get what your saying Brian.
    I was questioning that it appears that if the clamps are not preventatively oriented away from the lines that even with the recall done there can still be abrasion.
    Correct?
    As emac said it appears that there is room to avoid this issue now and maybe there was less room before the recall?
  25. Rifledriver
    37,288
    If the fuel hoses are routed and mounted correctly and the correct coolant hose clamps are used it should be impossible for an interference to take place. There is substantial space with the 2nd and 3rd generation fuel distribution block.
    The first TSB only addressed changing the hose clamp orientation from the way the factory initially installed them. It cannot be a permanent fix because that clamp is removed for routine service and for Ferrari to suggest that as a fix to prevent fire went beyond negligent. They knew there was a problem. They knew there had been fires and did nothing to stop it.
