F355 bursting into flames | Page 3 | FerrariChat
Discussion in '348/355' started by Drock28, Jan 17, 2016.
  1. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    I'm a optimist. It was a series of flutterblasters blamed on the roof LOL
  2. WATSON
    23,937
    WI
    Great. Now I HAVE to watch the damn video. Thanks for that :)
  3. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,186
    So. CA & NV
    Peter
    #53 TrojanFan, Jan 25, 2016
    My recall work was done less than 3 years ago and I have abrasion from something. It looks to me to be from the "tail" on the hose clamp. It appears that either whoever had replaced the clamp in the pass installed too large of one with excess "tail" on it or they did not insure that it was rotated property to avoid contact. In any case, I would think that should have been caught with they did the recall install but wasn't. I now have abrasion that has worn through the SS on the line and into the rubber.
  4. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    It I understand Brian correctly and from your example and the one in the video, the recall in its final design moved the lines far enough from the clamps that if prudent observation of the clamp and proper selection of size ( no long tail) is done, there shouldn't be a problem. If improper clamp selection and/or lack of attention to nut location on replacement, there could be an abrasion issue even with the recall done.
    I was not aware of this before this thread. Easy to check and get fixed if it needs to be and could save your car and much more.
  5. Rnye
    Rnye Karting
    Mar 17, 2014
    177
    Las Vegas, NV
  6. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Glad you found it! Scary.
  7. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    +1
  8. Robbe
    Robbe Formula Junior
    622
    The Netherlands
    Thanks. Because of you playing the video with the speakers turned up he has now removed the video , and is sitting in a corner with a head as a tomato....
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    LOL if thats all it takes
    I will make one myself with sound effects maybe a multi cam view
    I am proud to clear a room with farts, it's still one of my favorite things to do at 56 years young :)
  10. WATSON
    23,937
    WI
  11. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
  12. TrojanFan
    Nov 17, 2008
    5,186
    So. CA & NV
    Peter
    Update on my story. I took my car to the former dealer shop (still a shop - no longer a Ferrari dealer) expecting them to replace the hose free of charge as part of the original warranty. My mistake. The fuel block was the warranty part but its the same hoses as before. Apparently the previous owner, when they had the warranty work done had elected not to replace the worn hose. Mine is no longer rubbing but I'm not comfortable leaving the worn hose there. Its braided steel for a reason and exposed rubber underneath isn't a good thing.
    I could have replaced the hose myself but since my car was already at the shop, laziness took over and I gave them the go ahead to replace it. I can't believe that a simple braided hose is over $300! That's the Ferrari tax for you. No telling what the labor is going to be on top.
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    And you are Stooge number 4. Shame on you !!!
  14. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Great recap regardless Peter. Lessons learned!
  15. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    checked ricambi site......if it makes you feel any better some of the hoses are well over $400. You replaced the cheapest one! Feel better now?
  16. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    +1
  17. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    FBB, I should have been more precise in my description. Just the segment of oil line running under the manifold is a steel pipe. The rest of line on either side is the stock shielded oil line.
    My car goes in for servicing next month prior to Daytona. I'll take and post some pictures when the car is on the lift.
  18. TrojanFan
    Nov 17, 2008
    5,186
    So. CA & NV
    Peter
    Spoke to the shop today. The fuel line had to be ordered from Ferrari in NJ and should be in tomorrow. They are only looking at 1/2 hour of labor so having them do the work seems reasonable. I was kicking myself for being lazy and expecting a big labor charge. It would have taken me longer just to get my tools out.
