F355 C pillar cracking paint | FerrariChat
Discussion in '348/355' started by pmotoring, Feb 25, 2014.
  1. pmotoring
    pmotoring Formula Junior
    May 8, 2009
    693
    HONG KONG
    PAT PAT
    #1 pmotoring, Feb 25, 2014
  2. pmotoring
    May 8, 2009
    693
    HONG KONG
    PAT PAT
    #2 pmotoring, Feb 25, 2014
  3. phrogs
    phrogs F1 Veteran
    7,348
    Kzoo Michigan
    Nothing special.
    I would go ahead and beef up the welds along that seam. Just add some spot welds along it. Grind them flat. Add your favorite filler and go from there for paint.
  4. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Honolulu - Seattle - Okinawa
    Steve
    Yup, adding spot welds is the key. Bradan, a sponsor here, has shown that fix in detail with lots of pictures. It might be hard to find but it is in one of there service threads a couple years ago.
  5. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,898
    Richmond
    Pete
    I've seen the whole seam welded from the underside to prevent it ever happening again. You pretty much have to do that during the major, though. If I ever address it on my car, that's when it will be.
  6. fatbillybob
    Aug 10, 2002
    29,067
    socal
    Does this only happen on berrlinettas? I have only seen this on those 348 or 355.
  7. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Steve
    My GTS has what looks like slight bubbling in the paint there right in the seam. Nothing bad yet.
  8. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    common problem, I had mine fixed a few yrs back with welds...
  9. bigfatdog
    bigfatdog Rookie
    Dec 2, 2013
    27
    Houston, TX
    J.C.
    Fairly common on GTSs I've inspected over the years. The cracks are there if you look.
  10. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    Sand blast it good before applying filler, it may look rust free , but it 's there , sandblasting will ensure you got rid of all rust, then primer it , don't leave bare metal for any amount of time as it immediately starts to oxidize
    " serenity now "
  11. pmotoring
    May 8, 2009
    693
    HONG KONG
    PAT PAT
    Great thanks for your tips, will ask my body shop to do the spot wield. Any guys can show some pics of how it should be wielded . Really appreciate for help.
  12. phrogs
    phrogs F1 Veteran
    7,348
    Kzoo Michigan
  13. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Wow, the amount of filler in the OP's photos is really alarming..
  14. fatbillybob
    Aug 10, 2002
    29,067
    socal
    So are the mig welds in the repair.
  15. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Steve
    What is more surprising is seeing a 50's - 60's Fcar stripped to the bare metal. Get it close with the metal and then shape it with body filler was the M.O. It was shocking the first time I saw one naked.
  16. cuneo
    cuneo Formula 3
    2,472
    Wow, these are extreme cases obviously. My 1995 355 GTB has C-pillar cracks but they are so thin and minor that a guy with good eye-sight won't see them until about 2 feet away. I have 50k miles on the car now after purchasing it with 25k! :) Will fix it at the next major.
  17. pmotoring
    May 8, 2009
    693
    HONG KONG
    PAT PAT
    Thanks for the info....
    By the way is the spot wield be necessary, my body shop said the metal behind are in very good shape..
    Spot wield just to prevent future cracks?
  18. phrogs
    phrogs F1 Veteran
    7,348
    Kzoo Michigan
    Yes the welds are adding strength to that weak spot, unless you want to see them fixing the cracks again in the future I'd have them do what's shown In those photos. It will add the strength it needs.
