F355 carpet for 348 | FerrariChat
F355 carpet for 348
Discussion in '348/355' started by Actualizer, Jan 30, 2023.
  1. Actualizer
    Actualizer Formula Junior
    Hello
    I’ve done comprehensive search of threads.
    Can any of you amazing friends please confirm for me if a 355 OEM floor carpeting will fit my 1992 348 TS ?
    I’m being offered a 355 carpet in rosso in exceptionally remarkable condition but will it be a direct fit for my 348 ? Both cars are RHD.
    Thanks a heap
    Ash
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Pretty sure the center tunnel and behind it is different. I would be surprised if it was a direct fit. Can't say for sure about fit but the 355 definitely has a complexly different tunnel section.
    Actualizer likes this.
  3. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,883
    France
    Checking on eurospares it seems the "footwell carpets" are the same (same Ferrari parts numbers) for 348 and 355.
  4. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    The rear parcel tray is different from memory. How different depends on the 355 model the donor carpet is coming from. The 2.7 has no holes in the carpet for the ECUs and the 5.2 does. Also there is a difference with a Berlinetta and a GTS as the targa panel has the stowage spots to secure the roof.
  5. Actualizer
    Fed
    Indeed you’re correct . Thanks . Here’s a schematic of 348 vs 355 which shows difference . The 355 carpet is higher on the sides near kick panel and lower in the rear compared to 348.
    I wonder if a local carpet trimmer can cut and /or add carpet patch as 85% of real estate appears to be the same . Image Unavailable, Please Login
  6. ChoonHound
    ChoonHound Formula 3
    May 13, 2022
    2,221
    Saint Michaels, MD
    Lucas
    It’s a shame GAHH doesn’t sell a 348 specific carpet kit. I wonder if they’d make one if you sent them your old carpet to template.
  7. velocegiallo
    velocegiallo Karting
    101
    California
    FYI, I bought a roll of carpet from Re-Originals. I’m having it trimmed and installed in my 348 TS next month by an upholstery shop. I’ll take photos and post when I get it back.
  8. angelo puglisi
    angelo puglisi Karting
    Mar 27, 2006
    50
    348 carpets and 355 carpets are exactly the same, I have 355 carpets in my 348. The mats are exactly the same as well both cars share the same floor!!
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Good to know, thought for sure tunnel would be different carpet wise, as they are different tunnels.
    Sent from my SM-G990U using FerrariChat.com mobile app
  10. angelo puglisi
    Mar 27, 2006
    50
  11. angelo puglisi
    Mar 27, 2006
    50
    Tunnels are exactly the same. I have had both 355 and 348 side by side and they both measure exactly the same.
    Ferrarium likes this.
  12. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    The mats are not the same- at least on a RHD version. Slightly different shape around the handbrake and the carpet retainer on passenger side doesn’t line up with the 348 matt hole. They fit but slightly different.
