F355 Catalytic Convertor Thermocouples | FerrariChat
Discussion in 'Ad Archives' started by drbob101, Mar 26, 2015.
  1. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #1 drbob101, Mar 26, 2015
    These are direct replacement, brand new thermocouples that will plug and play on all f355s.
    They have the correct compression nut and stainless steel ferrule, correct length of cable and correct connector.
    If you need a longer cable for a custom exhaust modification, I can provide that as well.
    These are priced at $145 each. Compare to OEM at $290.
  2. chnco
    chnco Formula Junior
    Dec 20, 2014
    464
    Atlanta, GA
    Allen C
    Do you have the one directly after the bypass valve or are they one in the same?
  3. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    They are the same but I have made that one longer for some with capristo exhaust thst needed it.
  4. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    Did you have one for 85 308QV, USA model?
  5. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I have only done them for 355/360 but have not looked into doing them for 308s. I am reasonably sure it can be done. If you'd like to send me one I'll look into it.
  6. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    That 308 thermocouple is $500 on ebay. That's sick!
    Please send me your old one. I will match it for the same price I make up the 355/360 for. If I can't, I will let you know and I will send back your old one either way,
  7. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
  8. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Its that time of year getting ready for driving season. If you have SDL issues the TC could be your issue. These are priced at roughly 50% of OEM replacements.
    I have these made up for 348, 360 and 550/575.
    If you have another model that isn't listed above that needs TC, PM me and I will most likely be able to provide a replacement in the range that these are priced at.
