F355 Challenge Front and Rear Brake cooling ducts | FerrariChat
Discussion in '348/355' started by ShineKen, Feb 13, 2017.
  1. ShineKen
    ShineKen F1 World Champ
    19,892
    Southern California
    Nostradamus
    Anyone have pictures of what the front duct setup looks like? The standard 355 has 1 duct on each side, but I believe the Challenge cars have 2 ducts on each side (fronts).
    For those of us who have standard cars and challenge front bumpers, we have two options:
    1. Widen the FRP duct (the black piece that connects to the bumper) to fit the challenge bumper to keep the original single duct design.
    2. Purchase the challenge FRP duct which comes with 2 exit slots to run dual exit ducts which are then mounted on to an FRP disc which directly cools the brakes. You will have to find the FRP discs for both, which is rather hard to come by.
    I was lucky enough to find a full front and rear set from Japan, which will be in on its way in a few weeks. I am just not exactly sure how the FRP discs mount behind the rotors. Pics/diagrams would be appreciated :).
  2. 308 GTB
    308 GTB F1 World Champ
    11,717
    New Jersey
    Barry Wolinsky
    #2 308 GTB, Feb 13, 2017
  3. ShineKen
    19,892
    Southern California
    Nostradamus
    That's better than nothing. I couldn't find anything with a google search. Looks like you're missing a linking duct :). I am going to assume they don't stay on for very long.
  4. ShineKen
    19,892
    Southern California
    Nostradamus
    What exactly is the duct bolted to behind the rotor?
  5. 308 GTB
    11,717
    New Jersey
    Barry Wolinsky
    My front shock mounts were reinforced and the tech was putting everything back together when I took that picture. I'll look through other pictures to see if I have anything better.
  6. 308 GTB
    11,717
    New Jersey
    Barry Wolinsky
    #6 308 GTB, Feb 13, 2017
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    #7 SoCal1, Feb 13, 2017
  8. 308 GTB
    11,717
    New Jersey
    Barry Wolinsky
    Looks like you got 2,200 lb springs too, Tim.
  9. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,758
    Lake Villa IL
    I just plan to modify/make new single duct.
    I won't have challenge brakes or be on track so doubt getting or fabricating a dual duct setup would be needed.
  10. ShineKen
    19,892
    Southern California
    Nostradamus
    #10 ShineKen, Feb 13, 2017
    What's coming is:
    A pair of front FRP Discs.
    1 LH FRP front duct. I need to find an affordable RH FRP duct. There's one on ebay for $600, which is I think is too high. I need to take a splash off someone's :).
    A pair of rear FRP Discs.
    A pair of Challenge rear diffusers.
    And 4 beat up hoses and clamps.
    As long as I get these in my hands and figure exactly what is needed to mount the FRP discs behind the rotors, I will have a good solution :).
    Rothbauer_Racing likes this.
  11. ShineKen
    19,892
    Southern California
    Nostradamus
    It might be worth the wait for my solution than cut up your OEM duct. Unless you can find them cheap, then go for it. Doesn't hurt to have more cooling. Consider it as an added benefit to the bumper you bought :).
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Needs to carry all that weight LOL
  13. ShineKen
    19,892
    Southern California
    Nostradamus
    When you have the opportunity Tim, can you snap pics of how the disc mounts? Special bracket needed?
  14. 308 GTB
    11,717
    New Jersey
    Barry Wolinsky
    #14 308 GTB, Feb 13, 2017
    Screws and washers. It's illustrated in the parts manual. You should see the holes in the discs that you have.
    slracing likes this.
  15. ShineKen
    19,892
    Southern California
    Nostradamus
    Thanks Barry. I will check if a standard 355 has threads for mounting.
  16. 308 GTB
    11,717
    New Jersey
    Barry Wolinsky
    #16 308 GTB, Feb 14, 2017
    They won't be threaded, Ken. Installation of some of the Challenge kit components required some drilling. Even the clutch housing was drilled for ventilation...
  17. ShineKen
    19,892
    Southern California
    Nostradamus
    #17 ShineKen, Feb 18, 2017
    Nice! Never knew that.
    Diagram for fronts.
