F355 - Clicking noise from pumpkin | Page 4 | FerrariChat
Discussion in 'Technical Q&A' started by JeffBarber, Feb 19, 2014.
  1. JeffBarber
    JeffBarber Karting
    Feb 6, 2011
    175
    Lascassas, TN
    Jeff
    #76 JeffBarber, Sep 16, 2014
    See pic.
    Correct.
    Incorrect.
    I never said steel. I believe they are a bronze steel mix, many debates about the desired makeup of replacement guides on this site.
  2. fatbillybob
    Aug 10, 2002
    28,840
    socal
    Jeff,
    After some miles consider blackstone oil and coolant tests as indictors of head gasket leaks. Oil testing is a good thing to do early and a good thing to do to find out when is the best time to change your oil for how you use your car.
    There is much controversy on head gaskets and Ferrari HG leaks. Many real pros say no copper spray or in a less friendly way copper is for those who don't know how to rebuild a head. I have always used copper and never had any leaks but my total number of engines done is low compared to real pros. Another Friend of mine has done at least 1/2 dozen head jobs on 348/55's within the last 1/2 dozen years, also with stock HG's and copper with no leaks. One was a race motor. It would be great to hear how yours does for additional datapoints. There are all kinds of great sounding reasons for not using copper and only one reason for using copper...you have no leaks. I'm sure you will be joining our database of no leak stock HG's. Tim...you are sharp guy with lots of experience in this area. What do you think about copper on fiber gaskets?
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #78 Dave rocks, Sep 17, 2014
    Yep, I did not say you said it. It's been said all over this site that the new guides are sintered steel. See attached letter from FNA.
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,208
    CT
    John Kreskovsky
    More likely manganese-bronze.
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Thanks Jeff got the installed height, I went right past that in adobe reader. I will need to look at the head to figure that one out.
    I have no issue with the composite gaskets at all, they are whats to be
    Only consideration is, has that gasket been optimized for that engine meaning is it a second or third generation release of that gasket.
    Sealing is all about machining, I'm sure Dave can chime in here.
    Proper torque plates in place before machining, controlled part temperature, tool offset control. correct mounting of part.
    The gasket today controls expansion more then sealing in the old days
    So deck that block cut those heads LOL I got a new Christmas song in the making.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Looks like they are using the bottom of the cam shaft bores as a reference to the valve height. One could make up a half round tool and use a depth mic to measure.
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Perfect, that will work
    Dave how would you cut the valve to fit? Grinder, diamond, stone or machine it?
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #83 Dave rocks, Sep 17, 2014
    When you say cut, do you mean length? If so, depending on how much needs to come off, I would either surface grind the top or use a cut off wheel in a surface grinder then grind the top flat.
    My guess is the OP only needed to trim a small amount, say .005"-.010" (to compensate for the lapping of the seat) and that would be best done via a surface grinder. Any more and I suspect one would have a problem with the location of the key (keeper) grooves.
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    OK great, yes I think the vendor stated up they have a puck on top that is made for cut to fit I just wanted to be sure on the correct method.
    Much appreciated :)
  10. DB188
    DB188 Rookie
    Jul 7, 2013
    33
    North Yorkshire
    db
    I would swop you by pass valve for the capristo one which if it fails will fail to the open position and not to the closed as the factory one does
  11. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Subscribed for archive
  12. texas Bob
    texas Bob Rookie
    May 25, 2014
    13
    austin, tx
    Just put my 348ts pumpkin back together with a rebuilt pressure plate & T/O bearing + NEW SEALS ETC. ( failed T/O resulted in broken Pressure plate fingers )
    same deal --- rattling noise like an exhaust system rattle. It goes away when clutch depressed and can make less by playing with clutch release.
    did not re-grease fly wheel because minimal grease in pumpkin.
    Convinced noise is coming from fly wheel as all the other parts are solid pieces where as the fly wheel has a lot of stuff in it and when you depress clutch fly wheel stops turning = no rattle
    BIG QUESTION HERE IS - WHAT WILL HAPPEN IF THE FLY WHEEL INNARDS FAIL??
    VIBRATION? MORE NOISE? LOCKUP ?
    No problems shifting etc. --- just this scary noise when I sit out of gear & clutch out.
    like when you get out to open the gate or garage door.
    ps: you guys are great - love you almost as much as I love My 1990 JET BLACK 348 ts
    Texas Bob
  13. Brewman
    Brewman Formula Junior
    Apr 3, 2012
    417
    NC Mountains @ Boone
    Joe
  14. texas Bob
    texas Bob Rookie
    May 25, 2014
    13
    austin, tx
    Hello All
    After sending my last post I realized I made a mistake. Depressed clutch only stops the dual clutch assembly from turning. the fly wheel is direct connection to engine and keeps turning.
    Considering fly wheel is turning at over 1000 rpm & higher centrifugal force should prevent any thing from rattling. Same logic eliminates the dual clutch assembly from rattling with
    clutch out.
    I have no noticeable vibration --- COMPLETELY LOST AS TO WHAT IS GOING ON
    ANY IDEAS
    TEXAS BOB
