F355 coil-on-plug conversion | Page 17 | FerrariChat
Discussion in 'Technical Q&A' started by jeffdavison, Oct 22, 2004.
  1. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    732
    Continental Europe
    May I add that the 5V design of the combustion chamber may be even more efficient at pushing the mixture towards the centered spark plug as the piston goes up during the compression stroke than more conventional 4V combustion chambers.
  2. Timmo
    Aug 26, 2017
    732
    Continental Europe
    f355spider and redwedge like this.
  3. Timmo
    Aug 26, 2017
    732
    Continental Europe
    @f355spider
    I happen to have right now in the garage NGK PMR7A, CR7EIX and CR8EIX lying around. They all measure exactly the same.
    f355spider likes this.
  4. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    493
    London
    Steve C
    What coils are those please @Timmo
  5. Timmo
    Aug 26, 2017
    732
    Continental Europe
    The coils are the same Densos as used on previous installs.
    FWIW here is a confirmation that everything is running well. The plugs now look the same as on my 550 which runs John's COP set up, whilst with the stock ignition on the F355 the plugs always looked richer than this. This sort of confirms my initial impression that 2.7 cars need this type of upgraded, stronger ignition to run the way they should always have.
    redwedge likes this.
  6. redwedge
    Sep 30, 2012
    493
    London
    Steve C
    I was afraid you might say that. They're hard to come by new here in there UK.
  7. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,837
    Lake Villa IL
  8. Timmo
    Aug 26, 2017
    732
    Continental Europe
    Yes, as mentioned. Not sure yet where I'll have them made.
  9. Timmo
    Aug 26, 2017
    732
    Continental Europe
    They are hard to come by new anywhere as they are not made anymore.
  10. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,837
    Lake Villa IL
    Thanks. Did not see you mention it unless assumed because of the same coils.
  11. f355spider
    f355spider F1 World Champ
    18,059
    #411 f355spider, Sep 9, 2024
    Interesting. I installed the CR7EIX many years ago (I didn't pay attention to any differences), and a couple years after, I had a major service performed at the Ferrari dealer and they removed them and showed me the nose projection differences and sent me photos. I should have saved the photos. The CR7EIX was clearly shorter. But perhaps the specifications of the CR7EIX has changed?
    It was because of this thread I originally installed them in my car (5.2 Motronic). But after the dealer discovery I have stuck with the factory plug, until I later sold the car.
  12. Carmellini
    Carmellini Formula 3
    Jul 16, 2019
    1,013
    PMR7A application is Ferrari 355 and F50. That's it. This plug has a solid terminal and will not work with Denso/pencil style coils which require a threaded stud.
    CR7EIX, (CR8EIX), CRP7EAIX-9, and CR7EIA-9 all have threaded stud; will fit and work.
    Like the PMR7A, they all share
    -19 mm reach
    -1.0 mm pitch
    -5k ohm resistor
    PMR7A
    -platinum center electrode
    -platinum ground electrode
    -.028" gap
    -2.0 mm projected tip; but listed as non-projected
    CR7EIX, (CR8EIX)
    -iridium center electrode
    -nickel ground electrode
    .031" gap
    -1.0 mm projected tip; listed as non-projected
    (this is 1.0 mm shorter than oem)
    CRP7EAIX-9
    -.035" gap
    -3.0 mm projected tip; listed as projected tip
    (this is 1.0 mm longer than oem)
    CR7EIA-9
    -/035" gap
    -1.8 mm projected tip; listed as non-projected
    (this is 0.2 mm shorter than oem)
    All must be gapped to .028"
    By the numbers, CR7EIA-9 is the most similar to PMR7A. Only a 0.2 mm projected tip difference,
    and iridium center electrode vs. platinum. Everything else is the same including platinum ground electrode.
    @Timmo: why did you choose to go with CR8EIX? This plug is one number colder (8) than factory
  13. Timmo
    Aug 26, 2017
    732
    Continental Europe
    #413 Timmo, Sep 11, 2024
    The plug originally recommended for the F355 2.7 is the PMR8A, and the PMR7A for the 5.2.
    The CR8EIX is simply the Iridium upgrade to the original PMR8A.
    BTW the CR8EIX and CR7EIX I purchased came gapped to 0.7 mm / 0.028".
    Carmellini likes this.
  14. Carmellini
    Jul 16, 2019
    1,013
    @Timmo thanks for clarification. Any idea why the 2.7 plugs are colder?
    Do you have before and after fuel trim info? Would be curious to see that data.
  15. Timmo
    Aug 26, 2017
    732
    Continental Europe
    @Carmellini
    I do not think it is possible to get fuel trim info on pre OBD cars like the 2.7.
    As for colder plugs I am not sure but logic would suggest a higher dynamic compression ratio, through a higher static compression and/or advanced IVC. The pistons seem to be the same for both the 2.7 and 5.2 but the parts catalogues show different part numbers for the camshafts.
  16. f355spider
    18,059
    The difference in the CR7EIX versus PMR7A seemed more dramatic than 1mm in the photos my dealer sent me. Looked like 2 or 3mm. Not sure what if any negatives there were to that. The car ran fine for a couple years on them.
  17. Carmellini
    Jul 16, 2019
    1,013
    Agreed. In this picture it looks like the reach of the threads is greater on the PMR7A (right)?
  18. Timmo
    Aug 26, 2017
    732
    Continental Europe
  19. Timmo
    Aug 26, 2017
    732
    Continental Europe
    As a follow up to installing COPs on my 2.7 F355 and in order to boost the coils which are paired in series, I added in the loop a HKS Twin Power ignition box, after successfully installing one my 550, as per John Cribb's initial set up. This has tightened up further the way the engine runs with the COPs and it runs yet a little smoother, with more instant torque down low, a slightly quicker throttle response and at last but not least a sharper and more precise engine note right up to 8500 rpm. The engine feels healthier and like it's not working as hard as before, if that makes sense.
    A well worth and simple upgrade IMO that allows extracting more performance from the Denso coils.
  20. 355 P4
    355 P4 Karting
    Oct 13, 2020
    135
    So. California
    Bill Krueger
    I wrote an entire description of what I have and what I've done and it simply vanished so I'm just going to include the photos of my 2 stage coil conversion.
    Qavion, ShineKen and f355spider like this.
  21. f355spider
    18,059
    Bill,
    I hope you will post videos when this is running on the track. The noise this car makes on a flyby must be amazing.
  22. ShineKen
    ShineKen Two Time F1 World Champ
    20,162
    Southern California
    Nostradamus
    In regards to CR8EIX, NGK’s site lists it at .031” gap
    https://www.ngk.com/ngk-4218-cr8eix-iridium-ix-spark-plug
    Apparently, there are people selling them on Amazon with .028” gap.
    https://www.amazon.com/NGK-CR8EIX-Iridium-Spark-Plug/dp/B000VZJ712
    Either the seller is listing the spec incorrectly or he is gapping them to .028”. I’d want to double-check on that.
    I run the HKS Twin Power and Iridium plugs on my FD RX-7 for 80k+ miles. Solid responsive, simple setup.
    The HKS Twin power would do good for the platinum plugs as well.
  23. ShineKen
    20,162
    Southern California
    Nostradamus
  24. ShineKen
    20,162
    Southern California
    Nostradamus
    I also can’t seem to find them in .028” spec anywhere else other than Amazon.
  25. ShineKen
    20,162
    Southern California
    Nostradamus
    I’m not finding any CR7EIX gapped at .028” either.
    Someone should message the Amazon seller to double-check if he listed the spec correctly.
