F355 Compression Test results | FerrariChat
Discussion in 'Technical Q&A' started by angelboy, Mar 13, 2005.
  1. angelboy
    angelboy Formula Junior
    Jun 16, 2004
    416
    Up North - UK
    Paul
    Got my F355 Spiders test results back today.
    It's a 1997, Manual with 23,500 miles on it.
    1 - 11.4 bar - 165.4 psi
    2 - 10.9 bar - 158.1 psi
    3 - 12.2 bar - 177 psi
    4 - 13.2 bar - 191.5 psi
    5 - 12.6 bar - 182.8 psi
    6 - 13.1 bar - 190 psi
    7 - 12.9 bar - 187.1 psi
    8 - 12.9 bar - 187.1 psi
    Does this sound about right?
    The first two seem to be low in comparison. What do you think is the problem/can be done?
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,966
    The Cold North
    Tom
    Wow!! Those numbers are all over the place. Take that car for a good STRONG blast down a desereted streach of rd. Really ring it out, and get those RPM's up there. Go back and do the test with the eninge still warm..and see what you get..looks to me that you are a city deweller with your car..LOL
    If these number turn up to be the same..your timing could be out on one bank. I'm assuming the numbers as you have writen them corospond to the correct cylinder in the engine..
  3. ashsimmonds
    ashsimmonds F1 World Champ
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    yeah a couple seem a bit low, nothing alarming but certainly eyebrow-raising. i'm no techie so you can wait for someone else to pitch in some methods for elucidating the cause...
    what prompted you to do the test?
  4. ashsimmonds
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    the Italian Tune-Up! :)
  5. 360CS
    360CS F1 Rookie
    Nov 1, 2003
    2,641
    Kent
    Joe J
    Ive bnoticed that my CS appears to be not as noisey in RACE MODE as it was....can the valves get stuck etc....
    any ideas had similar probs??
    joe
  6. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    It is the differance between the cylinders that is most important as the actual readings are dependant on many factors ( battery cond. starter efficiency,gearbox oil temp ,ambient temp , accuracy of the gauge ,water temp ,etc. etc. ). A 5 % variation is normal and up to 10 % acceptable .
    Your readings do seem a little odd I would run it for 1000 miles and recheck them before the warranty expires .
  7. angelboy
    Jun 16, 2004
    416
    Up North - UK
    Paul
    Hi Wally,
    I'll try that, thanks.
    You know the situation with my car but the main dealer has told me that the results are fine. You'd think they'd jump at the chance to an expensive repair wouldn't you?
    What was your results?
  8. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Paul,
    As I said in PM all 8 between 10.5 & 11.0 Bar . This test was done as part of the acceptance checks for Ferrari to put thier Power warrenty on the car ,they had to do it twice as I had reqested a print out of the readings the first print had to be logged with F.
    Wally.
