F355 Coolant Rust and Fluid loss. | Page 2 | FerrariChat
Discussion in '348/355' started by lemon355, Oct 10, 2025.
  1. lemon355
    lemon355 Formula Junior
    Aug 8, 2009
    269
    Melbourne Australia
    Peter Kay
    I'm not an expert by any means so i take your point regarding the possibility of false +ve results on the Co2 test.
    Would a cylinder leak down test help..?
    Can enough pressure be applied to the combustion chamber to create bubbles in the expansion tank..?
    That is assuming its a flame ring burn out, or even pinholes in the cylinder liner..?
  2. ShineKen
    ShineKen Two Time F1 World Champ
    20,190
    Southern California
    Nostradamus
  3. ShineKen
    20,190
    Southern California
    Nostradamus
  4. ShineKen
    20,190
    Southern California
    Nostradamus
    #29 ShineKen, Oct 13, 2025
  5. ShineKen
    20,190
    Southern California
    Nostradamus
    If you order a Quinton Hazell FC518 cap, you will receive an “original” style cap, although they have a picture of the newer style version on their site. Confirmed by someone who has ordered and fitted one.
    lemon355 likes this.
  6. ShineKen
    20,190
    Southern California
    Nostradamus
  7. ShineKen
    20,190
    Southern California
    Nostradamus
    I’m not saying these are proven to be better, but perhaps an alternative to the Brazilian-made MTA caps. Only way to know is to buy it and test it every year or so.
  8. ShineKen
    20,190
    Southern California
    Nostradamus
  9. lemon355
    Aug 8, 2009
    269
    Melbourne Australia
    Peter Kay
    So I repeated the fluid test today, both on the exhaust and the filler neck.
    I ran a hose from the test chamber into the exhaust stream and used rags to divert exhaust gas to bubble through the test chamber and almost immediately, like my breath test yesterday the fluid went yellow.
    I brought the vehicle up to temperature, repeated the CCL Test and ran it for 10min.. .. No change in color..
    At the end of the test I revved the engine to 3k rpm.. No fluid bubbled up, and the test fluid still did not turn yellow.
    You can see how much air is bubbling out of the filler neck in the video @ 10min.( very little)
    Again.. I'm no expert but I cannot understand how in the world , if this is a CC leak into the cooling system, that it does not produce a +ve Yellow test..?!!?
    Something else must be going on here..?
  10. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    493
    London
    Steve C
    Is it not just oil mixing in from a failed heat exchanger?
    Timmo likes this.
  11. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    733
    Continental Europe
    Also been thinking about a failed heat exchanger but that was mentioned earlier in the thread already.
    How does gearbox oil look like?
  12. redwedge
    Sep 30, 2012
    493
    London
    Steve C
    Exactly, I'd drain that and see if there's coolant in it, seems the most obvious cause of brown coolant to me.
