355 - F355 - Cylinder head restoration shops | FerrariChat
355 F355 - Cylinder head restoration shops
Discussion in '348/355' started by fboutlaw, Jun 3, 2019.
  1. fboutlaw
    fboutlaw Formula Junior
    Dec 3, 2014
    260
    Woodside, CA
    Hey all,
    I'm in the market for a skilled machinist who can restore my tired F355 cylinder heads (leakdown was between 3-11% with one cylinder at 27%).
    I'm based in Northern California, but as I've sent out a lot of my parts around the US for refurbishment due to high costs and long lines for bay area machinists (+5 months at my mechanics recommended shop to get to the job). Anyone have any top notch recommendations in the US?
  2. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
  3. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Is this an example of 355 valve guides that does not have issues having an issue?
    Sent from my LM-Q710(FGN) using FerrariChat.com mobile app
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Check for shops that specialize in ducati race bikes, they have a few tricks that work "most excellent" with the 355 heads. Get the corrected timing from them also. ;)
  5. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    I’m confused, what do you mean?
  6. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ahh ok was not clear sorry. Is the issue with the heads the valve guides or something else not known?
  7. Sportflight
    Sportflight Rookie
    Aug 20, 2014
    13
    Call Daniel @ Bradan Coachworks - (631)585-8600
    He does excellent work, he is a sponsor here and is very knowledgeable in regards to the 355.
  8. fboutlaw
    Dec 3, 2014
    260
    Woodside, CA
    Leakdown:
    1 - 6%
    2 - 6.5%
    3 - 10%
    4 - 6%
    5 - 4%
    6 - 27% leaks from both intake and exhaust
    7 - 11%
    8 - 3%
    No leaks to the block past cylinders.
    I'm not 100% sure what the history is with the heads, but they're old and tired. There's a lot of buildup on the lower intake valves and some on the exhaust valves. I haven't checked the valveguides or seals yet, but the valve seats themselves need work. In the middle of pulling them off after testing.
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,221
    CT
    John Kreskovsky
    If the guides spec ok cutting the seats and replacing a could of valves is a DIY job.
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    I thought there was a good company in san louis obispo
    But cannot remember name
  11. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    757
    Vermont
    john truskowski
    Would be a shame to condemn the valve guides if the seals are the cause for the carbon buildup and subsequent leakdown :(
  12. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,554
    San Carlos, CA
    Mitchell Le
    He did not condemn the valve guides. He said it was tired and time for a valve job. Come to think of it, I have never seen a Cylinder 6 fail. Only CyL 2 or Cyl 7.
