F355 Dead battery | FerrariChat
F355 Dead battery
Discussion in '348/355' started by wrk2ownCT, Mar 22, 2015.
  1. wrk2ownCT
    wrk2ownCT Karting
    Nov 30, 2012
    134
    Madison CT
    Chris
    So my little guy was playing in the car while we wait for Spring and must have hit the interior lights:: Car is completely dead, Tried a trickle charger on the luggage plug, with no success. We are now gonna remove the front wheel and go direct with a 12 amp charger.
    If this doesn't work what is the recommended battery is a new one is needed?
  2. michael craig
    michael craig Karting
    Jan 28, 2013
    84
    NYC-Area
    I just did me 355 battery, the interstate battery is a great battery:)
    Mike NJ. 355 GTS
  3. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I just went through this on stone dead battery from the winter. I went and bought a new 34R Interstate and kept the old one as it was less than 2 years old and I just felt it wasn't in the grave yet. If your battery is of known age and you think it is less than 6 years , read on.
    As I learned with a generator battery from the guy in the service shop for small equipment, your regular battery charger or your trickle charger that are of the "smart" variety will not charge stone dead batteries. They need to see some life in them before they will charge it. The regular charger will throw a fault code of internally shorted battery. The trickle charger will do something similar but just wont charge it.
    This is what I did for my ice cold battery and it is now on the tender with a solid green light for two weeks.
    First if you are inclined, go to HF and get a $60 jump box. It will come in handy for a lot of the things around the house and is good to have.
    Fully charge it and then hook it up to your dead battery and leave it alone for a 24 hours.
    Then hook up a regular battery charger and it will now fully charge the battery. Again leave it on for 24hours.
    Then put the battery on your trickle charger and watch the lights. Blinking green means it is charging, solid green means it is charged.
    You can pull your battery and do this or do it through the posts in the engine bay.
    I now have a perfectly good spare battery and am light $140 because I was impatient in doing the above.
  4. KM1959
    KM1959 Formula Junior
    Nov 12, 2014
    984
    Kevin
    I just charged mine by connecting to the positive lead to one of the + terminals under the passenger side engine compartment splash panel. I clipped the negative lead to the transaxle case. It took at least 8 hours.
  5. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I will add one other thing to my experience as well. I was sure that I had left that I had the car on the trickle charger all winter although I admit to never monitoring the lights to see if it was working.
    In putting in the new battery and removing the one I had personally put in 2 years ago, i noticed some rusting of the rings of the trickle charger on the battery post. I flipped the rings around so that i could better get a 1/2" socket on the the terminal nuts and retightened them.
    I don't know if that was my issue but the car with the new battery is now on the trcikle charger as well and is solid green and I glance at the lights on the charger every time i walk through the garage now.
    If you are going through the process above, take the time to check your battery connections and make sure they are good.
  6. wrk2ownCT
    wrk2ownCT Karting
    Nov 30, 2012
    134
    Madison CT
    Chris
    Thanks, this was a new battery: interior lights left on for 4 days (I didn't notice as its under cover)-- left it on 12A charger all day= nothing...
    What's the best make/model to get)
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,244
    CT
    John Kreskovsky
    Doesn't the existing battery have a warranty? If it went dead after 4 days with the interior lights on you can hardly blame the battery. Some times they will come back, some time not.
  8. Rice-Racer
    Rice-Racer Formula Junior
    Jan 10, 2015
    252
    Just a note, once a battery has been fully drained/killed, they usually suffer 'some' irepairable damage. Ferrari here in western Canada at least, said they had changed out around 5 a week(Ferrari factory batteries) that are about a year or two old, and putting in Interstate. Try an overnight full 10 amp charge, check levels first if possible, then a trickle charge a day. Disconnect, take amp reading, probably 13+ volts, let sit overnight or a day and recheck 'rest voltage', what it stabilizes at. Then trickle charge again and leave on a tender, see if it saves it (of course, clean posts/clamps and grease them up as well)
