F355 engine suddenly loses power | FerrariChat
Discussion in '348/355' started by ClausH, Aug 18, 2017.
  1. ClausH
    ClausH Rookie
    Dec 9, 2015
    1
    Denmark
    Claus Haumann
    Hi. Im the happy owner of a yellow F355 with manual gear. during driving the periodically loses power, I guess some spark plugs are not igniting. I have heard this a common problem on 355 / 355 engines, and it is some coils that needs to be exchanged. The problem is on / off during driving..?
  2. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Claus, I had the same issue with my 355.
    Changed one of the coils, and never had the problem again.
    (Ferrari Part No. 138255)
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Much more information is required to properly diagnose this issue...
    - What year is your 355?
    - Did you get a CEL? and if so, did you check the codes?
    - Did you get a SDL?
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,981
    Isle of man- uk
    Are you sure the fuel pump is not playing up ? If it was plugs or coil you would expect to hear it back firing or missing
  5. F355Bob
    F355Bob Formula 3
    Mine did it. Bad cat ecu would out of the blue, cut out a bank of cylinders.
