F355 F1 -99 with leaking gearbox, need advise | FerrariChat
Discussion in 'Technical Q&A' started by AndersJL, Jun 7, 2010.
  1. AndersJL
    AndersJL Formula Junior
    Apr 16, 2001
    376
    Sweden
    AL
    I have come across a very nice F355 F1, but it has one catch: the gearbox is leaking. During the first test ride, every time I changed gears, the red warning light came on, and some times, during accelerating, it did not change up to higher gears than 3:rd or 4:th.
    Coming back to the garage, we discovered a weat area on the floor (red oil = hydraulic). We checked the oil level and found it was so dry that you could not even see the oil on the stick. We tried to locate from where it was leaking, but could not tell.
    I do not expect anyone to tell me (without having inspected the car) from where it is leaking, but does anyone know from experience, from where IT PROBABLY is leaking ?
    And, if it is very expensive to fix ?
    The guy selling the car says he has tapped up with new oil, and the gearbox now is shifting perfectly, but of course, still leaking...
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    There are too many variables to say for sure where it's leaking but one thing is certain, An F355F1 with gearbox trouble is not "very nice".
    You are asking for some expensive repairs if you buy the car.
  3. BigTex
    79,380
    Houston, Texas
    Bubba
    The system has no problems running up a $15K USD repair bill.....
    That said, you might find a specialist that can give you an estimate, but you are going to need to fix it right away .....
  4. BigTex
    79,380
    Houston, Texas
    Bubba
    Tim,
    IIRC, there's been a lot of upgrades to the parts???
    I thought I had seen an "improved" pump........
  5. darth550
    Jul 14, 2003
    61,144
    In front of you
    BCHC
    Awesome, you got a 355?
  6. darth550
    Jul 14, 2003
    61,144
    In front of you
    BCHC
    When did that happen? There are no multitudes of pictures..... :)
  7. AndersJL
    Apr 16, 2001
    376
    Sweden
    AL
    Oooops, so eventhough the car is in close to perfect condition, it sound like believing it is just a matter of changing a gasket or so...might be a bit too optimistic...?
    Maybe better to walk away this time. Too bad, I really wanted that car.
    Anyone with experience in these gearboxes out there to comment ?
  8. BigTex
    79,380
    Houston, Texas
    Bubba
    Give this thread a little more time......
    If everything else aout the car is excellent, it is unfair to blame the F1 system, it was brand new as of this model and eventually became very reliable...
  9. lightning
    lightning Formula Junior
    Apr 19, 2010
    551
    Stockport
    Martin Oliver
    #9 lightning, Jun 8, 2010
    Can you not get the car to a local specialist for a quick look on their ramp?
    You could say to the seller "Hey, I like your car but before I buy it just need to find out where that leak is coming from" You'd probably have to offer to pay the specialist to put it on their ramp and have a look, but if you had to pay $100 it would be worth it to find out if it's an easy or difficult fix.
    That's what I would do, if I liked the car. You could negotiate on price once you found out the repair cost. Say it's $2,000 you could offer to buy the car for $2,000 less, unless the car is cheap in the first place.
    If the seller won't oblige, it's time to walk away.
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    A seller who presents a car for sale with the gearbox oil level low enough to affect the operation of the system calls into question every other maintenance item on the car.
    Personally I'm not a big fan of paddle shifters and the 99 F1 was the first year of their gimmicky system. The cost of an F1 pump (quite possibly the problem) has come down some but is still a "big ticket" item and requires a shop with an SD2 to complete any clutch work.
    I recommend you take the car to a competent shop with an SD2 for an inspection. You will need to take it there for clutch repairs if you buy it.
  11. f355spider
    f355spider F1 World Champ
    18,044
    Depending on the extent of the leaks, and location, the engine/transaxle may have to come out and the two separated....
  12. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    It is most probably the tripple seal, common on both manual and F1. If so it is an real easy and cheap fix, did it my self on my 355 F1. If you need expert advice call Autocura.se and talk to Jim or Ronnie and say Johan sent you...
  13. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Buy a used 430 for 100k and incur a $40k repair.
    The dilemna of a used supercar...it is comprised of 50-100 parts each worth $10-$15,000 in potential repair value. Consider that the car only costs 5-10 times the individual part repair value. And put 1x-2x that repair value aside as 'repair insurance'.
  14. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    fortunately as mentioned above 360 pumps have come way down in price ($800!!!) and can be made to custom fit into a 355, although that's not easy as I understand.
    One possible leak that is cheap and easy to fix are the triple seals, when those leak the fluid will be coming from right under the 'pumpkin'.
    A more expensive leaks is the F1 actuator, which is on the bottom driver side of the engine.
    I loved every minute of my 355 F1 and highly recommend it!!! but as mentioned you really want to identify the source of the leak and get a price to fix it before making an offer on the car.
  15. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,211
    Michigan
    mark s
    I would be more concerned about the fact the owner was driving the car with such low fluid. How well is this car maintained? RED light to me.......or at least a caution
  16. lightning
    Apr 19, 2010
    551
    Stockport
    Martin Oliver
    Why not do what I suggested in post 9 above....get the car inspected by a specialist.
    In the UK there are specialists that will go and inspect a car for £100-400 (depending on level of inspection/type of car) and produce a report for you.
    I would imagine this is available in the USA?
  17. BigTex
    79,380
    Houston, Texas
    Bubba
    OP is in Scandinavia......
  18. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    OP is in Sweden.
  19. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    But we do have good Ferrari worlkshops arround here (Sweden) too...
    If you need help you can always call:
    AutoCura.se in Kinna
    Sportvagnsservice in Stockholm
    AutoRopa in Malmö
    Remo Special in Skene
  20. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    What is a triple seal?
    What is a "pumpkin"?
  21. Rifledriver
    37,101
    The two places it is probably not leaking.
  22. Rifledriver
    37,101
    Its leaking red oil.
    The F1 system is malfunctioning.
    The F1 reservior is empty.
    Tell me, which if any of those symptoms fits a triple seal leak?
  23. Rifledriver
    37,101
    You are asking a question that is impossible to intelligently answer without inspecting the car. This is the internet so naturally there are a couple of people who are perfectly willing to diagnose the car based on thin air and their inability to avoid giving advice when, for a multitude of reasons they should not.
    You need to have the car inspected by a qualified person. To not do so is folly. It is possible it is a simple problem that is easily fixed but it is equally possible it is serious and expensive.
    I will offer a general opinion of the car however. Good cars have owners who look after them well. They are not typically owned by individuals that would show them to a prospective buyer with a puddle of hydraulic oil on the floor and a fluid reservior so low on fluid that the transmission malfunctions.
  24. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    In the cars I have seen in passed years with F1 system leaks, it is one of two things. First there are rubber lines on the bottom of the tank that sometimes leak, a new hose and some clamps, not bad at all.
    Second are the feed lines to the actuator, they are high pressure braided stainless with banjo style ends. There are six different lines. This can get to be expensive quickly. I have seen aftermarket lines made to fit, but you need to send the line off to be matched.
    Rarely it is the shift actuator itself, but that is possible. BIG $$s.
    Get it to a shop and have them clean away the dirt and leaking oil and find out. Could be easy and worth the fix. Maintainance does not really keep this from happening. It could be well maintained and still develop this leak.
  25. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Amen. Add to this the fact that IF the owner was genunely unaware of the leak, he could have been driving it around for a while low on oil, with the pump cutting in and out like a loony trying to pressurise oil that simply isn't there....
