F355 F1 Gear Transmission problem | FerrariChat
Discussion in '348/355' started by Khushwant Nijjar, Jun 19, 2018.
  1. Khushwant Nijjar
    May 3, 2018
    1
    Khushwant Nijjar
    Hello everyone,
    I need an advice regarding F355 F1 gearbox transmission:
    The gears only change up to 4th and then seem to be stuck or drifting to 3rd or 2nd and when driving speed doesn’t go above 40 miles per hour. When the gear change the gearbox/hydraulic motor/pump in the back makes a bit noise of rather than shifting/changing gears smoothly.
    Spoke to one mechanics he reckons it could be the Electric motor in the gearbox hydraulics pump and other One reckons it could the speed/pulse sensor.
    Any advice from anyone may have faced the same issue will be highly appreciated.
    Thanks,
    Khush.
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    How long have you had the car
    Did you hit any big holes lately
    When were your engine mounts changed
    So it shifts fine 1, 2, 3, 4, R no 5 or 6??
    Hiw long for pump to prime
    How long for pump to reenergise when sitting but not shifting gears
    Does it shift when not running, fine
    Have you reviewed the service manual and how the f1 works so that you can give better feedback? This will help,a lot
  3. Qavion
    Qavion F1 World Champ
    14,436
    Ian Riddell
    Has your speedometer been behaving erratically recently?
    phrogs likes this.
  4. tres55
    tres55 F1 Rookie
    3,572
    Canada
    I had a similar problem before and I believe it was the speedo sensor that resolved it.
