F355 Front Compartment Relays. | FerrariChat
Discussion in '348/355' started by Geflackt, Aug 3, 2015.
  1. Geflackt
    Geflackt Karting
    136
    Eastern PA.
    #1 Geflackt, Aug 3, 2015
    On a '99 F355 F1 Spider, what are the (2) relays that are separate from the fuse block - located between the fuse block and trunk space. In the pic you can see one of these had been dislodged by the wiring harness. I was able to get the relay back in place and route the harness over the relay, but I'm wondering what those (2) relays are for.
    There is also a separate 15A fuse holder on a harness in this compartment. I haven't found any notes on this or the relays in the manual or shop PDF's.
    Thanks!
  2. NSXn355
    NSXn355 Rookie
    May 3, 2014
    48
    Northern NY
    Bill
  3. Geflackt
    Geflackt Karting
    136
    Eastern PA.
    Interesting! It is a car out of Canada. The front driving/fog lights are always on when the ignition is on, so I wonder if it's related to those lights.
  4. NSXn355
    NSXn355 Rookie
    May 3, 2014
    48
    Northern NY
    Bill
    That would be a good guess since Canada required day time running lights years ago.
  5. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    #5 348Jeff, Aug 3, 2015
