355 - F355 front lift kit | Page 2 | FerrariChat
355 F355 front lift kit
Discussion in '348/355' started by radback, Nov 7, 2023.
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,036
    Southern California
    Nostradamus
    7k/8k are the front and rear spring rates. Check a conversion table.
  2. radback
    radback Formula Junior
    799
    France
    Yes I know that :)
    What I don't know is what k is standing for.
    But I don't mind. I just know the sprins are stiffer than stock.
  3. ShineKen
    20,036
    Southern California
    Nostradamus
    308 GTB likes this.
  4. ChoonHound
    ChoonHound Formula 3
    2,267
    Saint Michaels, MD
    Lucas
  5. radback
    799
    France
    I remember a thread about stock spring rate. That was painfull.:)
    So I don't really care. Knowing those spring are stiffer than stock is good enough for me.
    But if you want to drop the OEM spring rate, I'll be interested to read it.
    (same units: k or lbs)
    ChoonHound likes this.
  6. radback
    799
    France
    Change of plans: car is stuck at the shop :(
    I was right about the above: I should have get the short rear springs.
    Those rear springs are too long to fit if the car is lowered.
    The spring perches are touching the anti roll bar system if set at low position:
    Even if set at original height it is too close, and could touch during hard drive.
    I've contacted Roberuta to get a pair of correct springs asap.
    To be continued...
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Thanks for the update
    Great info
  8. radback
    799
    France
  9. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,461
    Los Angeles
    That's fantastic. I would love that on my 355.
  10. radback
    799
    France
    You know where to get it:
    https://www.roberuta.com/english
    Tell them you've heard about it from Francois (me ;) )
    Kiyo is a very nice guy and very patient (I asked him dozen and dozen of questions before buying the kit).
    And he was very reactive by sending me in express a new set of rear springs to correct the issue with the long ones.
  11. ChoonHound
    2,267
    Saint Michaels, MD
    Lucas
    How does it drive? Pics of tank?
  12. radback
    799
    France
    Picture of tank page 1 of this thread.
    I drives normaly as cups are only inflated to pass big speed bumps or ramps.
  13. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    How hard do you drive it
    Ie
    Can you tell the suspension is different
    I just like the way mine handles and would not want it to be worse
  14. radback
    799
    France
    The suspension geometry is not set yet, I'll let the springs settle a little bit before doing it.
    Regarding stiffness, it is definitively harder than before but still comfortable (much more comfortable than my daily driver fitted with Bilstein B14 coilovers!)
  15. C-speed
    C-speed Karting
    Jul 13, 2022
    177
    Crescent Kao
    Hello,
    Did you happen to measure the diameter of those front cups? Are they same or smaller than the Stance 110mm cups?
    I measured the front strut mount pocket and from my measurements, the Stance 110mm cups will fit without modification or grinding.
    Thanks.
  16. C-speed
    C-speed Karting
    Jul 13, 2022
    177
    Crescent Kao
    * If my Googling is correct, it looks like Roberuta has 2 versions, a Large and Medium. If you have the medium 115mm version, then the Stance 110mm cups will certainly fit.
  17. radback
    799
    France
    #42 radback, Mar 29, 2024
    The picture you posted is from a generic kit I guess.
    Roberuta are making kits specifically for each car.
    For the F355 cups are 108 at bottom, but the top is machined and narrowed.
    As it is, the stance cup won't fit a 355. You'll have to grind it at the top. It is doable.
    Or you can also install them at bottom upside down, but it's not the best regarding cleanless of the cup.
    If I had the possibility to grind/install/remove/grind/install/remove/grind/install I may have go the Stance cup way.
    I couldn't, so I went to the only available option, the best one.
    Remember that the Roberuta kit is the only one solution to install a lift while keeping the original active suspension on an F355.
  18. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,685
    LA & OKC
    Kevin
    Great upgrade, thanks for sharing and documenting. Roberuta has been around forever, I remember they were prevalent in the high end Japanese car scene.
  19. PAP 348
    Dec 10, 2005
    100,234
    Mount Isa, Australia
    Pap
    This is great man! Thanks for sharing.
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I know a few people who have said H&R sport springs feel pretty good as an upgrade
    I wonder if they would work with this setup?
  21. radback
    799
    France
    No. Progressive springs don’t work with cups as far as I know.
    But the springs provided in the kit are great. Little stiffer than oem but not rough. I chose the street ones. Racing types are available too for those who don’t care about comfort.
    And with this system you can fit any kind of springs you want (kw etc…) as long they’re the straight types.
    Many to chose from…
  22. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    To lazy to reread whole thing but you only had to do something with the cups correct
  23. Chrisferrari355
    Aug 3, 2024
    9
    Chris Old
    Hi Radback. I wondered if you could help me on this. I spoke to DK engineering about installing the Roberuta lift kit for the front only. They have concerns over whether the factory specification can be reinstated if the system was removed and also the adaptive electronic system being modified and/or removed is likely to result in a warning light. Any help would be greatly appreciated. Thanks!
  24. radback
    799
    France
    Hi Chris,
    the Roberuta kit is designed to fit directly to the 355 while keeping the OEM active suspension system functional.
    There is no modification to be made on the car to install the kit, so you can also remove it to put back stock suspension.
    Only thing is to buy a spare set of spring perches as they need to be modfied to fit narrow springs.
    Hope this helps.
  25. Chrisferrari355
    Aug 3, 2024
    9
    Chris Old
    Thanks v much!
