F355 gas cap? | FerrariChat
F355 gas cap?
Discussion in '348/355' started by dantm, Nov 23, 2013.
  1. dantm
    dantm Formula 3
    Nov 1, 2003
    1,104
    YYZ, BOS, SFO
    Dan B.
    Is the F355 gas cap vented? Today I took my car out for a ride with half tank (or maybe slightly less) and after a spirited drive I was not able to put any gas in it for about 5 mins because of the outward pressure from the tank...
    I then looked at the gas cap and it's a solid piece of aluminium...I thought they were vented with a rubber seal on the inside? OR that is only newer cars (i.e. 360 and newer)?
  2. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,919
    Richmond
    Pete
    When mine is hot there is pressure in the tank but it vents quickly when I take the cap off. You may have a plugged or non-functioning valve somewhere. When I fill mine, I can hear a whistling noise that I believe is air venting as the gas goes in the tank, so there is a vent that I believe goes through the charcoal canister. Check Ricambi for the diagrams and you'll see there are a couple of valves in the system.
  3. dantm
    dantm Formula 3
    Nov 1, 2003
    1,104
    YYZ, BOS, SFO
    Dan B.
    I just had the fuel block recall done on the car -- could this have changed the behavior at all? I don't think I encountered this problem before I had the recall done.
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    When I release my cap it vents. When I fill, I hear a whistle sound...
  5. gaw111
    gaw111 Formula Junior
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    My 348 does the same thing. Never a problem, just wait till it stops venting.
  6. dantm
    dantm Formula 3
    Nov 1, 2003
    1,104
    YYZ, BOS, SFO
    Dan B.
    Ok thanks guys...one more request can somebody kindly take a pic of the inside of their gas cap and post it?
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Gas caps haven't been vented for a long time.
  8. dantm
    dantm Formula 3
    Nov 1, 2003
    1,104
    YYZ, BOS, SFO
    Dan B.
    #8 dantm, Nov 24, 2013
  9. mike_747
    mike_747 Formula Junior
    Dec 15, 2008
    794
    Seattle
    That is not a photo of a 355 gas cap. Inside the cap is a solid rubber "gasket" about .07"-.10" thick bonded to the inside of the cap. They can come off, just re-glue it needed.
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    He knows that, he posted a 360 cap..
  11. dantm
    dantm Formula 3
    Nov 1, 2003
    1,104
    YYZ, BOS, SFO
    Dan B.
    That is a 360 gas cap -- my post was in response to 2NA saying that gas caps have not been vented on F-cars for a while...
    My F355 does not have this vent (obviously); I think my gasket came off at some point since all I have is the glue inside of the periphery of the cap.
  12. dantm
    dantm Formula 3
    Nov 1, 2003
    1,104
    YYZ, BOS, SFO
    Dan B.
    Which also begs the question -- would a vented gas cap help the F355 owners who either have negative or positive pressure inside the fuel tank?
  13. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    #13 saw1998, Nov 25, 2013
  14. KMR968Turbo
    KMR968Turbo Formula 3
    Nov 11, 2007
    1,001
    Calgary, Alberta
    Erik
    Interesting. After stopping for fuel after a spirited run in the F355 the gas cap practically launches into my hand when I open it. I learned to take it off very slowly or at least be ready to catch it when it comes free. Is that normal?
  15. Shurik355
    Shurik355 Formula Junior
    May 19, 2013
    297
    USA Tulsa, OK
    Alex Velet
    ok bringing this thread back to life. A few questions were unanswered above.
    And I do have the same thing happening that whenever Im about to fuel up, while taking the cap off it releases the pressure for about 3 seconds.
    Well I just recently bought a new gas cap. And the inside the cap there is a difference in the rubber seal. Was there a design change?? anyone know??
  16. PaulK
    PaulK F1 Rookie
    4,801
    Michigan
    Paul
    I'm not sure if they updated the gasket of not, but it IS normal for it to vent.
    It could be the two way breather valve, as shown in the picture (the red thing). I replaced mineas it was a little plugged up.
    When you remove it you should be able to blow in the line.
    But yes the tank should be under pressure.
    Here's my adventure:
    https://www.ferrarichat.com/forum/threads/anti-rollover-valve.599310/
  17. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Top one OEM? And the bottom a newer aftermarket?
